Can't execute a Nagios plugin wmi for wql
akalb
Post by akalb »
i want to execute a wmi query passing only 2 parameter. For example please take a look at my vbs script below. In this example I want pass the first sql query parameter ("Select * from Win32_ComputerSystem") and the second parameter ("UserName"). I try it using the standard plugin check_wmi_plus.pl but it doesnt' works. Maybe I have to use other solutions. Please help me as soon as possible. Thanks a lot. Bye, Kalibert
' Sample VBScript to discover which user is logged on
Option Explicit
Dim objWMIService, objComputer, colComputer, strComputer
strComputer = "MyPcName"
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" _
& strComputer & "\root\cimv2")
Set colComputer = objWMIService.ExecQuery _
For Each objComputer in colComputer
Wscript.Echo objComputer.UserName
Next
Re: Can't execute a Nagios plugin wmi for wql
Could you post how you ran the check and the error message you are receiving?
I tried the following check and it worked:
./check_wmi_plus.pl -H <client ip> -u <username> -p <password> -m checkusers -s count -a "name like '%lmiltchev%'"
OK - Number of Users=1 - User information shown on next line is: Name(FullName) |'Number of Users'=1;
 lmiltchev()
./check_wmi_plus.pl -H <client ip> -u <username> -p <password> -m checkusers -s count -a "name like '%fakeuser%'"
WMI Query returned no data. The item you were looking for may NOT exist or the software that creates the WMI Class may not be running, or all data has been excluded.
akalb
Post by akalb »
sorry I wish use a function like this
function GetResult(wmiClass,wmiField:string):string
SELECT wmiField FROM wmiClass
and next call this function passing myQuery for example GetResult(Win32_ComputerSystem,TotalPhysicalMemory) to obtain some value but I dont' undertand how can I do.
I guess I am confused. Can you give us some detail on what you want to check for?
