Backups not listed
BanditBBS
Backups not listed
Post by BanditBBS »
So I have multiple backups located in /store/backups/nagiosxi but when I click on the Local Backup Archives link, nothing is listed. At one point one was listed, but days ago that stopped being shown. I created a manual backup by running the script and also one by clicking the "Create Backup" button. Both are the only files in that folder right now.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Backups not listed
Can we get a ls -l of that directory's contents, and a ls -ld of the directory itself?
BanditBBS
Post by BanditBBS »
[root@iss-chi-nag05 nagiosxi]# ll
total 5723616
-rw-r--r-- 1 nagios nagios 2927474149 Apr  9 13:15 1428602570.tar.gz
-rw-r--r-- 1 nagios nagios 2927773916 Apr  9 12:58 nagiosxi.1428601502.tar.gz
drwxrw-rw-. 2 nagios nagios 4096 Apr  9 13:46 nagiosxi
Do you see anything in the "/usr/local/nagiosxi/var/components/scheduledbackups.log" that can give us some clues?
BanditBBS
Post by BanditBBS »
[root@iss-chi-nag05 ~]# cat /usr/local/nagiosxi/var/components/scheduledbackups.log
04-08-2015 01:00:01 DEBUG: Running scheduled local backup ...
04-08-2015 01:00:01 INFO: Creating a local backup: nagiosxi.1428472801
04-08-2015 01:00:01 DEBUG: Sending create local backup command to CmdSubsystem
04-09-2015 01:00:01 DEBUG: Running scheduled local backup ...
04-09-2015 01:00:01 INFO: Creating a local backup: nagiosxi.1428559201
04-09-2015 01:00:01 DEBUG: Sending create local backup command to CmdSubsystem
That's the entire file and the backup I created last night. It didn't complete due to a crashed table. That has been resolved and I deleted the folder that was never finished from that last night run.
Post by Box293 »
The XI backup component could be improved by:
  • Implementing alerting if a backup failed
    Backup logs that you can view in the XI interface (for each backup that ran)
BanditBBS
Post by BanditBBS »
Box293 wrote:The XI backup component could be improved by:
First we have to get it to display whats in the folder :lol:
jomann
Development Lead
Post by jomann »
Hey Bandit,
Can you check the permissions of the /store/backups folder? And if possible can you tail the Apache error_log when you click on the page that lists all your backups to see if there is an error in getting the list?
(As always, your feature requests are awesome I will add them to the never ending todo list)
BanditBBS
Post by BanditBBS »
[root@iss-chi-nag05 ~]# ll /store
total 20
drwxr-xr-x. 5 root root  4096 Apr  1 11:23 backups
No errors in the httpd error log! This is not the contents of the backups folder after last nights scheduled on:
total 8587392
-rw-r--r-- 1 nagios nagios 2929636061 Apr 10 01:12 nagiosxi.1428645601.tar.gz
Is apache part of the nagios group?
cat /etc/group|grep nagios
Also, just to verify, is selinux enabled?
getenforce
