Maps
OptimusB
Maps
Post by OptimusB »
I am looking to do more visual presentation of using maps in Log Server. However currently limited to World, Europe and USA. Are there any plans to expand on this? I've looked at the tile map in Kibana 4 and the ability to zoom. Any plans for similar implementation? Would also be nice to select a particular country (ie. Canada).
Thanks!
OptimusB
Re: Maps
Post by OptimusB »
I might have just replied my own question... I saw the option of "bettermap" which takes data from MapQuest. Unfortunately our servers do not have access to the internet :(
jolson
Attack Rabbit
Re: Maps
Post by jolson »
Kibana 4 is not currently on the roadmap. Regarding your map choice - bettermap will do what you want it to - however as you mentioned, you will need internet access to display the map properly. I looked around on the internet for some other options, but came up blank. If you find a way to insert a local map, please let us know about it so that we can take a look at it. Thanks!
Twits Blog
