EMail/SMTP Doesn't work
gzarif
Post by gzarif »
I'm new at this but I setup Nagios XI 14 and I'm trying to setup the email communication.
When I try to send a test email it doesn't work.
Where can i setup SMTP?
thanks,
G
jomann
Development Lead
Re: EMail/SMTP Doesn't work
Post by jomann »
You can set up SMTP in the Admin tab under the "System Config" section there is a page called "Manage Email Settings" that allows you to specify SMTP settings or sendmail.
gzarif
Post by gzarif »
Got it thanks.
cmerchant
Post by cmerchant »
Did you get your email setup ok? Can we go ahead and close this thread?
gzarif
Post by gzarif »
yes you can go ahead and close this thread
