package centos-release is not installed
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-6-server-optional-rpms
RESULT=1
Loaded plugins: product-id, rhnplugin
This system is receiving updates from RHN Classic or RHN Satellite.
You need to add the Optional software channel so that Nagios XI can install the necessary prerequisites. To do so, first sign in to your Red Hat Network account at http://rhn.redhat.com/. Then click on the link corresponding to your system. Near the bottom-left corner of the page, click Alter Channel Subscriptions. Check the box labeled RHEL Server Optional and click Change Subscriptions. That's it! You should be able to run the installer again and complete your installation.
