NCPA CPU Thresholds on MultiProc Host
dlausche
Post by dlausche »
I am using NCPA v1.8.1 on a Windows 7 host and am trying to setup simple CPU % thresholds in Nagios. What I am experiencing is that on a multi-core host all it takes is one of the cores/CPUs to be over the threshold and then an alert is generated.
in ncpa.cfg:
[passive checks]
%HOSTNAME%|cpu usage = /cpu/percent --warning 80 --critical 90
and this output for - https://localhost:5693/api/cpu/percent
"value": {
"percent": [
5.2,
84.4,
8.7,
14.1,
With only the one CPU above the threshold the result is Warning yet the overall CPU use for the four CPUs is really < 30%. How do I configure it to use a combined percentage of all CPUs considered together? I am looking for the CPU metric shown on the NCPA dashboard that is labeled "Current" and is to the right of the CPU use graph.
Re: NCPA CPU Thresholds on MultiProc Host
Try this:
https://localhost:5693/api/cpu/percent?aggregate=avg
dlausche
Post by dlausche »
Perfect. That is exactly what I am looking for. I've been reading the NCPA API docs for hours trying to figure out how to do this. I didn't find anything explaining how to aggregate or average like this.
Thanks much!
cmerchant
Post by cmerchant »
Looks like we can go ahead and close this thread. Thanks.
