NRPE: Unable to read output
stecino
Post by stecino »
I have two nrpe clients
[root@blah2 etc]# /usr/bin/sudo /usr/local/nagios/libexec/check_file_age -c 30 -f /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out
FILE_AGE OK: /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out is 1 seconds old and 94518751 bytes
[root@blah1 etc]# /usr/bin/sudo /usr/local/nagios/libexec/check_file_age -c 30 -f /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out
FILE_AGE OK: /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out is 1 seconds old and 96979751 bytes
command[check_nnsjp_oc4j_file]=/usr/bin/sudo /usr/local/nagios/libexec/check_file_age -c 30 -f /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out
root@server:/usr/lib/nagios/plugins# ./check_nrpe -H xx.xx.xx.2 -c check_nnsjp_oc4j_file
root@server:/usr/lib/nagios/plugins# ./check_nrpe -H xx.xx.xx.1 -c check_nnsjp_oc4j_file
FILE_AGE OK: /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out is 0 seconds old and 97044990 bytes
on both servers
-rwsr-sr-x 1 root root 3050 Dec 15 2013 check_file_age
in sudoers file -- nagios ALL=(ALL) NOPASSWD: /usr/local/nagios/libexec/check_file_age *
what else can be wrong with the server throwing NRPE: Unable to read output
jdalrymple
Skynet Drone
Re: NRPE: Unable to read output
Post by jdalrymple »
selinux is well known for causing that problem...
Is NRPE working at all? What if you just do
stecino
Post by stecino »
jdalrymple wrote:selinux is well known for causing that problem...
It is working, I get NRPE 2.15 version back
SELinux is disabled
Post by Box293 »
Can you please post your nrpe.cfg file on the remote server.
stecino
Post by stecino »
Box293 wrote:Can you please post your nrpe.cfg file on the remote server.
Attached the NRPE client config. Please note: this it is compiled not accept command arguments, therefore arguments are hard coded
I will be changing this in the future, but for now I am trying to fix this particular problem
nrpe.cfg
(10 KiB) Downloaded 125 times
Post by Box293 »
Does the nagios user have permission to access the plugins and file?
ls -la /usr/local/nagios/libexec/check_file_age
You might need to enable debugging on the remote server.
Type vi /etc/rsyslogd.conf and press Enter
Type /var/log/messages and press Enter
This takes you to the line in the config file we are after, it will look like:
*.info;mail.none;authpriv.none;cron.none               /var/log/messages
We need to add ";daemon.debug" to the line:
*.info;mail.none;authpriv.none;cron.none;daemon.debug               /var/log/messages
Save and exit
Type service rsyslog restart and press Enter
Type sed -i 's/^debug=.*/debug=1/g' /usr/local/nagios/etc/nrpe.cfg and press Enter
Type service xinetd restart and press Enter
Now you can watch the NRPE debug informations sent to /var/log/messages
stecino
Post by stecino »
it can run this
sudo -su nagios /usr/local/nagios/libexec/check_file_age -c 30 -f /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out
FILE_AGE CRITICAL: /u01/app/oracle/product/10gr202/j2ee/nns_jq/log/nns_jq_default_island_1/oc4j.out is 997 seconds old and 135995951 bytes
stecino
Post by stecino »
I also had debug turned on in the config for nrpe. That's all I got upon executing the command
Apr 15 17:11:34 ...a2 nrpe[11676]: INFO: SSL/TLS initialized. All network traffic will be encrypted.
Apr 15 17:11:34 ...a2 xinetd[4177]: EXIT: nrpe status=0 pid=11676 duration=0(sec)
Post by Box293 »
stecino wrote:Apr 15 17:11:34 ...a2 nrpe[11676]: INFO: SSL/TLS initialized. All network traffic will be encrypted.
Did you do the syslog steps as well? Without these you won't get much info.
