Reports are hanging
mkeil77
Reports are hanging
Post by mkeil77 »
since a couple of days we're not able to send any reports by email.
to generate the report as PDF or CSV is working but as soon as we want to sent them by clicking the 'Save/Send' link the browser is hanging.
we already checked all available reports but it's all the same.
I also noticed that the PDF attachment for scheduled reports are not readable any more.
regards
Matthias
Re: Reports are hanging
Are you seeing this issue with ALL reports?
Try to send a report, then run the following command and show us the output in code wraps:
tail -50 /var/log/httpd/error_log
mkeil77
Post by mkeil77 »
Yes with all reports.
I think i found the reason for the problem. as per the below log Nagios is trying to use the external/public IP to generate the report.
This is of course not working if I'm on the local LAN since then the access to the external IP is blocked by the firewall.
But why is Nagios not using his internal IP?
--2015-04-20 07:24:29-- http://xxx.xxx.xxx.xxx/nagiosxi//report ... S&mode=pdf
Connecting to xxx.xxx.xxx.xxx:80... failed: Connection timed out.
Retrying.
--2015-04-20 07:25:33-- (try: 2) http://xxx.xxx.xxx.xxx/nagiosxi//report ... S&mode=pdf
lmiltchev wrote:Are you seeing this issue with ALL reports?
Reason: Removed sensitive information
Have you entered by chance an external URL under the "System Settings"?
Admin->Manage System Config
