This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
cloudcom
Posts: 67 Joined: Tue Jul 02, 2013 1:41 am
Post
by cloudcom » Wed Apr 15, 2015 4:14 am
I am trying to understand some nagios concepts. I saw host and service obsession under the monitoring process
By default they are disabled. I found some information but did not understand exactly
Can you explain what it means and when it is used, please?
jdalrymple
Skynet Drone
Posts: 2620 Joined: Wed Feb 11, 2015 1:56 pm
Post
by jdalrymple » Wed Apr 15, 2015 10:20 am
Host/Service obsession is generally used in distributed Nagios monitoring where you need a Nagios server to send results to a NSCA daemon. If you don't have a specific use case I wouldn't enable it.
This page outlines host and service obsession.
cloudcom
Post
by cloudcom » Wed May 06, 2015 5:22 am
you can close the topic.
thanks for the answer
