Had a change of staff and we do not know the root pw for our nagios appliance. We are able to log into the GUI so I was wondering if we can reset the pw from their.
Running Nagiosxi 2014R1.3 on vmware esxi 5.1. Nagiosxi appears to be running cent os 6.5
We used to have it it licensed, but I belive it has expired...
Upon logging into the gui it complains about DB errors, but we still receive alerts.
The goal is to migrate the vm to another system, but we are unable to because we don't know the root password...
Cheers!
Reset nagiosxi appliance pw from gui
Re: Reset nagiosxi appliance pw from gui
You can reset nagiosadmin's password from the CLI by running the following commands:
where you substitute <newpassword> with the actual password you want to use.
I would also recommend running the database repair script from with the same directory (scripts):
You can use Nagios XI for free if you monitor up to 7 hosts. From the web UI, go to Admin->License Information->Free (Limited edition without support), and click on "Update License".
Hope this helps.
./reset_nagiosadmin_password.php --password=<newpassword>I would also recommend running the database repair script from with the same directory (scripts):
./repair_databases.shHope this helps.
- Box293
- Too Basu
If you are talking about the CentOS password for root, follow this procedure:RLD wrote:Had a change of staff and we do not know the root pw for our nagios appliance.
http://wiki.centos.org/TipsAndTricks/ResetRootPassword
