Hi Team,
I have a simple question for you. Because I don't found my prescious on Forum.
When I apply new version of NagiosXI 2014, every bandwith change to Mbps on Gbps with warning 0,0 and critical 1,1.
I don't understand why Nagios change this ..
Do you any answers for me ?
Kind regards
Upgrade NagiosXI problem Bandwith
Re: Upgrade NagiosXI problem Bandwith
What is the version of Nagios XI and the "Network Switch / Router" wizard that you are currently using? What is the XI version that you upgraded from? Can you show us an example (screenshot) of the error? Also, show us the actual command that you are running from the CLI along with the output of it.
My old Nagios was in 2014R2.0 and the new version in 2.6.
For Wizard Network Switch now is on 2.1.7 and the last version I think 1.6 or 2.0.
My example : check_xi_service_mrtgtraf!192.168.xxx.xxx_26.rrd!6,6!7,7!G
Thanks a lot
Thanks a lot
When the Wizard is run, it will detect the speed of the ports and automatically adjust the speed for the checks.
When you run the wizard, you can change the default port speed and the warning/critical rates to the settings that you prefer.
