[root@localhost libexec]# ./check_disk --help
check_disk v2.0.3 (nagios-plugins 2.0.3)
Copyright (c) 1999 Ethan Galstad <[email protected]>
Copyright (c) 1999-2014 Nagios Plugin Development Team
<[email protected]>
This plugin checks the amount of used disk space on a mounted file system
and generates an alert if free space is less than one of the threshold values
check_disk is monitoring free space, not used space. If the value of free space is LESS THAN the threshold you set, that's when things are bad. Make sense?
