No MSSQL_Lock_Reqests_Per_Sec Performance Graph Data
hillhealthcenter
No MSSQL_Lock_Reqests_Per_Sec Performance Graph Data is being displayed after December 2014.
Thanks so much,
Tom
Tom
Re: No MSSQL_Lock_Reqests_Per_Sec Performance Graph Data
I think the uom may have changed in the plugin (in an update) as it was incorrect prior to Dec. What does the check's performance data look like currently?
hillhealthcenter
Please see the attached.
Thanks so much,
Tom
Tom
Those negative values are very odd. I wonder if there was an overrun. Do you have any errors in the perfdata logs?
grep centcshdb /usr/local/nagios/var/perfdata.log
grep centcshdb /usr/local/nagios/var/npcd.logFormer Nagios employee
hillhealthcenter
login as: root
[email protected]'s password:
Last login: Thu Apr 16 16:17:51 2015 from 192.168.102.150
[root@nagiosxi ~]# grep centcshdb /usr/local/nagios/var/perfdata.log
2012-07-27 18:03:04 [11045] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2012-10-03 08:47:10 [13819] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2012-10-27 04:42:36 [18202] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2012-10-27 07:45:31 [5699] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_C__Disk_Usage"
2012-11-20 09:36:58 [14495] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Memory_Usage"
2012-11-30 13:22:27 [14186] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2012-12-05 11:00:23 [10857] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2012-12-06 17:22:26 [28129] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Ping"
2012-12-07 11:11:31 [2851] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_D__Disk_Usage"
2012-12-09 15:34:54 [14122] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2012-12-17 21:58:23 [5567] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-01-09 09:53:04 [28866] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2013-02-05 00:04:18 [28672] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2013-03-12 20:19:16 [18300] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2013-03-26 06:57:11 [2262] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-03-29 00:14:12 [20327] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-04-22 00:05:09 [25940] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Ping"
2013-04-25 15:33:39 [9167] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_C__Disk_Usage"
2013-05-08 15:03:57 [7877] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-05-13 12:37:51 [2363] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-05-13 13:52:52 [15247] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2013-05-15 00:52:53 [24368] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-05-16 11:37:30 [4868] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2013-05-22 19:42:23 [5414] [0] *** Timeout while processing Host: "centcshdb" Service: "Memory_Usage"
2013-05-25 19:02:47 [8295] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2013-05-30 23:22:54 [397] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2013-05-31 06:12:54 [13139] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2013-05-31 20:52:56 [24433] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-05-31 20:52:56 [24437] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2013-06-01 10:12:53 [660] [0] *** Timeout while processing Host: "centcshdb" Service: "Memory_Usage"
2013-06-01 17:50:50 [12677] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Ping"
2013-06-01 18:20:50 [4906] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Drive_C__Disk_Usage"
2013-06-03 05:02:38 [3687] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-06-03 18:02:48 [32471] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-06-03 20:32:50 [27521] [0] *** Timeout while processing Host: "centcshdb" Service: "CPU_Usage"
2013-06-04 16:47:52 [12923] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2013-06-06 01:35:48 [9964] [0] *** Timeout while processing Host: "centcshdb" Service: "CPU_Usage"
2013-06-07 04:20:49 [26881] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Ping"
2013-06-07 09:27:45 [12572] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2013-06-07 17:52:47 [27309] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-06-08 01:07:50 [21260] [0] *** Timeout while processing Host: "centcshdb" Service: "_HOST_"
2013-06-08 07:52:46 [20234] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-06-10 12:57:40 [18158] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-06-12 11:12:37 [6155] [0] *** Timeout while processing Host: "centcshdb" Service: "Memory_Usage"
2013-06-16 11:23:20 [17433] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-06-16 13:13:16 [13569] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
2013-06-16 13:53:16 [14827] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2013-06-19 02:18:03 [25121] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-06-30 19:03:04 [20737] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_E__Disk_Usage"
2013-07-10 12:47:47 [25214] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Memory_Usage"
2013-07-12 06:03:08 [24738] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_D__Disk_Usage"
2013-07-23 15:47:22 [6858] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-07-24 00:33:21 [31509] [0] *** Timeout while processing Host: "centcshdbtest" Service: "Drive_C__Disk_Usage"
2013-07-30 17:33:17 [11691] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_C__Disk_Usage"
2013-09-25 09:44:49 [27917] [0] *** Timeout while processing Host: "centcshdb" Service: "Drive_D__Disk_Usage"
2013-09-25 09:44:49 [27912] [0] *** Timeout while processing Host: "centcshdbtest" Service: "_HOST_"
2013-10-06 17:12:22 [702] [0] *** Timeout while processing Host: "centcshdbtest" Service: "CPU_Usage"
2014-09-17 17:22:22 [17640] [0] *** Timeout while processing Host: "centcshdb" Service: "Memory_Usage"
2014-11-06 11:15:10 [32623] [0] *** Timeout while processing Host: "centcshdb" Service: "Page_File_Usage"
2014-12-19 06:19:29 [1788] [0] *** Timeout while processing Host: "centcshdb" Service: "Ping"
[root@nagiosxi ~]#
[root@nagiosxi ~]# grep centcshdb /usr/local/nagios/var/npcd.log
[root@nagiosxi ~]#
Thanks so much,
Tom
Tom
Could you enable the npcd logger as per the FAQ:
http://support.nagios.com/wiki/index.ph ... h_Problems
Wait 15 minutes, and then rerun the grep:
grep -2 centcshdb /usr/local/nagios/var/npcd.logFormer Nagios employee
hillhealthcenter
Could you go to Admin > Manage Config Wizards and post back the version of the MSSQL Server Wizard?
Could you provide a screen capture of the advanced tab for that service so we can see the performance output?
hillhealthcenter
Here is the wizard.
Thanks so much,
Tom
Tom
hillhealthcenter
Here is the MSSQL Lock Requests Advanced tab.
Thanks so much,
Tom
Tom
