Error: Could not read object configuration data!
rameshAGB
Post by rameshAGB »
HI im new to Nagios.
Installed Nagios3 in Ubuntu server , as given
https://help.ubuntu.com/lts/serverguide ... figuration
After the installation, Im able to login to index page, but other link shows "Error: Could not read object configuration data!".
Test
1.Verify configuration options using the -v command-line option to check for errors.
2.Check the Nagios log file for messages relating to startup or status data errors.
both shows, configuration is fine. Any one can help one this ?
abrist
Red Shirt
Re: Error: Could not read object configuration data!
Post by abrist »
This is most likely a permissions issue. You need to verify that your web group (apache or www-data usually) has permissions on the nagios directory:
grep nag /etc/group
ls -la /usr/local/nagios/share
venkatklr
Post by venkatklr »
Even I am getting same error. Apache is on same group. Please help!
Have you done this:
Also, have you tried restarting apache2?
Is SELinux enabled?
venkatklr
Post by venkatklr »
yes SELinux is enabled.
abrist
Red Shirt
Post by abrist »
Please disable selinux for testing purposes, and then try again. You may have issues with context.
setenforce 0
venkatklr
Post by venkatklr »
Still same issue.
abrist
Red Shirt
Post by abrist »
Can you post the output of:
service nagios status
ps -aef | grep nagios.cfg
grep nag /etc/group
ls -la /usr/local/nagios/sbin
ls -la /usr/local/nagios/var
cat /etc/httpd/conf.d/nagios.conf
venkatklr
Post by venkatklr »
PFA...
logsofNagios.docx
(94.49 KiB) Downloaded 552 times
If you are using Ubuntu, In the "/etc/group" you should have "www-data" instead of "apache":
nagios:x:1000:nagios,www-data
nagcmd:x:1001:nagios,www-data
If you are on RHEL/CentOS, you should have:
nagios:x:1000:nagios,apache
nagcmd:x:1001:nagios,apache
Do you have any config errors?
Ubuntu (repo):
nagios3 -v /etc/nagios3/nagios.cfg
Source Install:
According to your screenshot, nagios is NOT running...
Try:
rm -f /usr/local/nagios/var/nagios.lock
service nagios3 start
or
service nagios start
Check to see if nagios is running:
ps aux | grep nagios
