Evaluation Nagios Log server, have one question.
joaase
Post by joaase »
Hi.
Hope i create this topic right.
I testing just now Nagios Log Server with a trial license. And so fair its a great log monitor Tools.
I have one question that i hope someone can help me with so i can convice my cheif that Nagios log server is best Tools for my Company.
My question is. Can i create a panel that show me top 10 events base on "Event ID" from my windows servers?
what i mean is if i have 10 event with following numbers, 1,1,1,1,1,2,2,2,3,4. i will show in my panel that i have 4 event with number 1 , 3 event with number 2 and so on
so i can se that event number 1 is that events that show most and i should try to solve it first.
Best Regards
Joakim
eloyd
Cool Title Here
Re: Evaluation Nagios Log server, have one question.
Post by eloyd »
Yes, you can do that. You may need to create a dashboard histogram widget to show exactly what you are looking for, but once you have searched based on Event ID, you can then display that information in many ways.
Ask if you need more specific help.
jolson
Attack Rabbit
Post by jolson »
As eloyd said, if you have the log values in a field already, you can generate a graph based on that information:
Best,
Jesse
Twits Blog
joaase
Post by joaase »
Thx.
I find how too do.
//Jocke
jolson
Attack Rabbit
Post by jolson »
Sounds good - may I lock this thread and mark as resolved?
Twits Blog
joaase
Post by joaase »
Hi.
Yes You can lock it.
//Jocke
jolson
Attack Rabbit
Post by jolson »
Will do. Locking it now.
Twits Blog
