I have tried to setup nagiosgraph and but it keeps giving me issues.
It has the service graphs as blanks/there is no output.
Can someone tell me how to remove it from the nagios server.
Nagiosgraph Removal/uninstall.
jdalrymple
- Skynet Drone
Re: Nagiosgraph Removal/uninstall.
It doesn't look like the developer provides an uninstaller or even instructions.
The parts that I expect it *broke* within the existing XI installation I would guess are in commands.cfg:
Have you looked over the install.pl file to see what it does?
command_name process-host-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.host
command_name process-host-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/perfdata/host-perfdata.$TIMET$
command_name process-host-perfdata-pnp-normal
command_line /usr/bin/perl /usr/local/nagios/libexec/process_perfdata.pl -d HOSTPERFDATA
command_name process-service-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.service
command_name process-service-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/perfdata/service-perfdata.$TIMET$
command_name process-service-perfdata-pnp-normal
