NRPE Install Error
costanza2k1
NRPE Install Error
Post by costanza2k1 »
Hi all,
I'm trying to install a NRPE agent on a RHEL server, can you help me out with this:
Running './2-usersgroups'...
Adding users and groups...
useradd: group nagios exists - if you want to add this user to that group, use -g.
groupadd: group 'nagios' already exists
groupadd: group 'nagcmd' already exists
usermod: user 'nagios' does not exist
ERROR: User 'nagios' was not created - exiting.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './2-usersgroups'
agent used: http://assets.nagios.com/downloads/nagi ... ent.tar.gz
Re: NRPE Install Error
Post by Box293 »
For some reason you already have the users and groups created and the installer doesn't like this.
This command will comment out the part that creates the users and groups.
Change into the directory that has the fullinstall script and type:
sed -i 's/run_sub .\/2-usersgroups/#run_sub .\/2-usersgroups/g' fullinstall
Now run the full install and see if it works.
costanza2k1
Thanks, that worked...this can be closed.
