How to monitor windows nic status?
phyo
Post by phyo »
HI,
How can we monitor the windows interface status by using snmp?
Thanks.
Re: How to monitor windows nic status?
Post by Box293 »
You can use our Network Switch / Router Wizard which will poll the status and bandwidth utilization of the ports on the device. This will be graphed for you.
This topic might also help:
http://support.nagios.com/forum/viewtop ... 16&t=29686
phyo
Post by phyo »
Box293 wrote:You can use our Network Switch / Router Wizard which will poll the status and bandwidth utilization of the ports on the device. This will be graphed for you.
Wow, this wizard also can monitor windows nic status. Now i can monitor the windows server nic status.
Thanks Box293
