Looking for GUI Host creation tool for Nagios
I am looking for a better host creation tool. I have found few in nagios page, but there is no specific step by step integration documentation. Anyone could help me with this. I am looking for a open source Host integration tool(Like Lilac) for my Nagios(4.0.8).
Regards
Sazzad
Sazzad
Re: Looking for GUI Host creation tool for Nagios
Thanks for your reply! I have checked the the documentation & i think i need your help, as your working on currently in your system.
In the documentation following lines are there:
But in my system there is no such subfolder named www. What should i need to do? Could you suggest!Download and extract
Download the latest NagiosQL Version from www.nagiosql.org and extract the nagiosql-*.tar.gz to a directory accessible by your webserver (e.g. /srv/www/htdocs). A subdirectory "nagiosql" will be created:
root@RR-DE-NMS-2:/home/rr-de-nms-2# cd /srv
root@RR-DE-NMS-2:/srv# cd www
bash: cd: www: No such file or directory
root@RR-DE-NMS-2:/srv# ls -lrt
total 0Regards
Sazzad
Sazzad
Which distribution (and version) are you using?
Rob Hassing
I am using nagios 4.0.8 Version.
My Nagios file distribution is as follows:
I have downloaded package from bellow path::
I have used bellow URL as guideline to install my Nagios::
root@RR-DE-NMS-2:/usr/local/nagios# ls -lrt
total 28
drwxrwxr-x 2 nagios nagios 4096 Apr 16 11:06 bin
drwxrwxr-x 2 nagios nagios 4096 Apr 16 11:06 sbin
drwxr-xr-x 2 root root 4096 Apr 16 11:14 include
drwxrwxr-x 3 nagios nagios 4096 Apr 16 11:14 libexec
drwxrwxr-x 11 nagios nagios 4096 Apr 16 11:14 share
drwxrwxr-x 3 nagios nagios 4096 Apr 17 11:18 etc
drwxrwxr-x 5 nagios nagios 4096 Apr 20 09:11 varI think bellow info could help you a little bit understand more:
root@RR-DE-NMS-2:/usr/local/nagios# ls -l /etc/apache2/sites-enabled/
total 4
lrwxrwxrwx 1 root root 35 Apr 16 08:34 000-default.conf -> ../sites-available/000-default.conf
-rw-r--r-- 1 root root 982 Apr 16 11:07 nagios.confRegards
Sazzad
Sazzad
I meant which version of Linux are you using?
Ubuntu, CentOS, Debian, Fedora or Something else?
Rob Hassing
Ubuntu 14.04.2 LTS (GNU/Linux 3.16.0-34-generic x86_64)
Regards
Sazzad
Sazzad
You should check what the default document root is in Ubuntu.
I think it is
I think it is
/var/www/Rob Hassing
I am following bellow URL::
But When i login through the following steps, it shows not foundmessage. What could be the possible reason? It seems my webpage cant discover the nagiosql32 installation web page!!
Regards
Sazzad
Sazzad
Maybe you can check your http log files?
I think they are in /var/log/httpd/
Rob Hassing
