I have a Cluster of Files Server under win2012. It is setup as Actif/Actif.
I wanna monitore it with my Nagios.
I add wmic binary file to check wmi.
All is good for example :
- wmic -U 'Domain\admin'%password --namespace='Root\cimv2' //192.168.174.230 "select * from win32_process"
=> Good result.
But if I wanna check root\MSCLUSTER I get error :
- wmic -U 'Domain\admin'%password --namespace='Root\MSCluster' //192.168.174.230 "select * from MSCluster"
[wmi/wmic.c:212:main()] ERROR: Retrieve result data.
NTSTATUS: NT code 0x80041010 - NT code 0x80041010
I find out where my error comes : it is becouse the Namespace root\mscluster need pktprivacy to by chech in remote access.
The problem is how to use pktprivacy with wmic ? I try with option
--use-security-mechanisms=Pktprivacy but is doesn't work.
Other solution : how disable the pktprivacy for the namespace ?
Thanks for your help
Gérald
Using Wmic to monitore W2k12
jdalrymple
- Skynet Drone
Re: Using Wmic to monitore W2k12
From a high level - I see 2 solutions.
1) Doesn't appear to be possible - but can you relax the security mechanism requirements for that WMI namespace? I didn't see a quick solution to doing that.
2) If the Linux wmic isn't going to work, would it be possible to replicate the check using a Powershell script and run it remotely? If you need help with this we can probably give you some guidelines.
GeraldGeniaut
thanks for your reply. I don't want to use powershell script like a nrpe system. Actually I'm looking for downgrade the security of the namespace but...
It is very strange that wmic can't ask with this type of security, becouse I read in stackoverflow that for IIS6 it is the same security level. I'm sure that there are plenty of admin whose need to monitore IIS with wmi. I hope their solution will work for me.
Thanks !
Gérald
Thanks !
Gérald
Gérald, let us know if we can lock this topic and mark it as "resolved".
GeraldGeniaut
Yes if I find a solution, I'll post it here and tag as resolved.
jdalrymple
- Skynet Drone
GeraldGeniaut,
as you know we rely on wmic for these checks. While it's a great tool, in-house knowledge of it just doesn't exist. You might point this problem out to the develoepr:
http://www.aldeid.com/wiki/Wmic-linux
