[check_winprocess.pl] Configuration Help
sh.shekhar89
Post by sh.shekhar89 »
Hi All,
I am trying to configure to check a process memory utilization and cpu utilization using check_winprocess.pl (https://www.itefix.net/check_winprocess)
Can some one guide me how to configure?? I have copied the .pl files in nagios folder and .exe file in windows ns client script folder. but when i am running the command on nagios server , i am getting this below error :
[root@test libexec]# ./check_nrpe -H 192.168.199.1 -c check_proc_cnt
No handler for command: check_proc_cnt
can some one guide me??
jolson
Attack Rabbit
Re: [check_winprocess.pl] Configuration Help
Post by jolson »
It does not look like the plugin 'check_winprocess.exe' includes an NRPE listener, unless I'm missing something. You need an NRPE listener to accept incoming connections from your Nagios server. A few popular plugins that can listen for NRPE are as follows:
http://www.nsclient.org/
http://exchange.nagios.org/directory/Ad ... PA/details
I personally like NCPA, but NSClient is a very respected application as well. I recommend researching them both, and testing to see which one you prefer.
Please let us know if you have any questions. Thanks!
Twits Blog
sh.shekhar89
jolson wrote:It does not look like the plugin 'check_winprocess.exe' includes an NRPE listener, unless I'm missing something. You need an NRPE listener to accept incoming connections from your Nagios server. A few popular plugins that can listen for NRPE are as follows:
Hello jolson,
But i have seen many people are using this plugin to check the process memory.
Can anyone help me in configuring this plugin??
jolson
Attack Rabbit
Post by jolson »
What version of NSClient are you running?
Do any other checks work?
Could you please post your nsc.ini file? I would like to take a look at it to ensure that NSClient is properly configured for this plugin.
Twits Blog
sh.shekhar89
jolson wrote:What version of NSClient are you running?
i am using 0.4.1.73, i have attached nsc.ini file.
nsclient.ini
(7.39 KiB) Downloaded 288 times
jolson
Attack Rabbit
Post by jolson »
Did you restart NSClient on the Windows machine you're trying to monitor?
From an administrator command prompt:
net stop nscp
net start nscp
Then retry your NRPE check from Nagios.
If that does not work, please stop NSClient and enable test mode:
net stop nscp
cd "C:\Program Files\NSClient++"
nscp.exe test
Then retry your check - what errors are you getting in the terminal?
Let me know what you find out.
Twits Blog
sh.shekhar89
jolson wrote:Did you restart NSClient on the Windows machine you're trying to monitor?
net stop nscp
net start nscp
net stop nscp
nscp.exe test
This is the output i am getting when i am running the above command
test.txt
nscp test
(7.69 KiB) Downloaded 268 times
jolson
Attack Rabbit
Post by jolson »
Do any other NRPE checks work?
Everything looks good as far as I can tell.
It doesn't look like there's any 'test' input - meaning the listener didn't receive any data. Otherwise we would see errors - make sure that port 5666 is accessible through your Windows Firewall.
Twits Blog
