Plugin fails only from remote host
zlacelle
Post by zlacelle »
I'm trying to get a plugin to work (check-ubuntu-apt) on some Ubuntu hosts. On some it works, but on others it fails. The strange thing is that, if I run the plugin as the nagios user on that host, it succeeds. The failure is NOT the typical SSL failure, and other nagios checks are succeeding.
The failure is internal to the plugin, but difficult to track down. I'm trying to understand what in the environment could be causing the failure.
Command I'm running:
"sudo -u nagios /usr/lib/nagios/plugins/check-ubuntu-apt"
Return is fine:
"All packages are up-to-date.|valid=1,pending=0,security=0,non-security=0"
However, when I run on my monitoring machine "/usr/lib/nagios/plugins/check_nrpe -H <hostip> -c check-ubuntu-apt", I get
"Querying pending updates failed.|valid=0,pending=0,security=0,non-security=0"
Here is the debug output in my syslog:
Apr 20 16:29:33 host nrpe[27259]: Running command: /usr/lib/nagios/plugins/check-ubuntu-apt
Apr 20 16:29:33 host nrpe[27259]: Command completed with return code 3 and output: Querying pending updates failed.|valid=0,pending=0,security=0,non-security=0
Apr 20 16:29:33 host nrpe[27259]: Return Code: 3, Output: Querying pending updates failed.|valid=0,pending=0,security=0,non-security=0
My entry in /etc/nagios/nrpe.cfg:
command[check-ubuntu-apt]=/usr/lib/nagios/plugins/check-ubuntu-apt
I don't understand how those two things can return different codes.
jdalrymple
Skynet Drone
Re: Plugin fails only from remote host
Post by jdalrymple »
selinux and/or apparmor could cause this behavior, are they disabled?
Post by Box293 »
Can you provide the plugin check-ubuntu-apt.
Does the plugin perhaps write a temp file somewhere like /var/tmp/ ? If so, does it have appropriate permissions to do so?
