Hi
After using Nagios support forum for the past few weeks, here are my questions.
How can I mark my question as closed/resolved by myself ?
Can I delete my own question/post ?
Can I edit subject line after it got posted ?
forum usage questions
jdalrymple
- Skynet Drone
Re: forum usage questions
You can't, let us know and we'll close and lock it right away. Also let us know if you think it should be marked solved - all we do is change the post icon to a green check, you could do that yourself if you wish.nagmoto wrote:How can I mark my question as closed/resolved by myself ?
I'm not sure if regular users can do this or not. If you can - it's a checkbox right at the top when you click "EDIT"nagmoto wrote:Can I delete my own question/post ?
It looks like it will let me on the EDIT screen, will it not let you?nagmoto wrote:Can I edit subject line after it got posted ?
Since it's hard for me to see what your screen looks like I shared the view as a mod so you can get an understanding of what we see.
At the end of the day - feel free to ask us publicly or via PM and we'll gladly change anything for you if it seems appropriate.
1.) We mark up the posts when they are solved according to our own needs, so just let us know when it is resolved and we will handle it for you.
2+3.) There should be a delete button in the top-right corner of each of your posts, and there is also an "Edit" button that can affect the body of your post, not sure about the subject line. Try them out! I haven't been a regular user on this forum, but looking at the permissions I don't think the deletion is possible.
- 2015-04-21 09_11_05-forum usage questions - View topic • Nagios Support Forum.png (4.84 KiB) Viewed 838 times
