Notification of a NEW host
JohnFLi
Post by JohnFLi »
Is it possible to have it set so that when a new host is added, that a notification gets sent to a person (or people)?
The reason for this is that I have 4 other Admins that also add systems to Nagios and some of them always mess something up.
If I can get notified when a new system is added, I can go in and make sure its done right.
Everybody is somebody else’s weirdo
jdalrymple
Skynet Drone
Re: Notification of a NEW host
Post by jdalrymple »
Use this and count the number of *cfg files in /usr/local/nagios/etc/hosts/ maybe?
JohnFLi
Post by JohnFLi »
that might work, put i get an error when trying to run it
]# ./check_files.pl
Can't locate Date/Parse.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_files.pl line 159.
BEGIN failed--compilation aborted at ./check_files.pl line 159.
Post by Box293 »
yum -y install perl-TimeDate
BanditBBS
Post by BanditBBS »
Or use this quick script I just wrote since I loved your idea and suffer same thing here!!!!
#!/bin/bash
# Check for new hosts
# by Jim Clark / banditbbs @ gmail . com
# Get current count of host files
current_count=$(ls /usr/local/nagios/etc/hosts | wc -l)
# Check for this script running before and if not create dummy file
if [ ! -f /usr/local/nagios/libexec/hostcount ]; then
    echo "1" > "/usr/local/nagios/libexec/hostcount"
fi
# Read old count file
old_count=$(head -n 1 /usr/local/nagios/libexec/hostcount)
# Compare counts
if [ "$old_count" -lt "$current_count" ];then
  echo "Warning - New host has been added!"
  echo $current_count > "/usr/local/nagios/libexec/hostcount"
  exit 1
fi
  echo "OK - No new hosts added"
  exit 0
I'm not in the office to test this, but pretty darn sure it is bug free 8-)
EDIT #1: Wait, dont use it yet, have to update it to write the new count to the file
EDIT #2: Ok, fixed. You'll have to set max checks to 1 as when it detects and exits with a warning, it'll return to OK on the very next check.
EDIT #3: Connected to work and fixed the bug I had in it, lol
EDIT #4: Added code correction in following post.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
rseiwert
Post by rseiwert »
Need to account for the case when hosts are deleted. I'm fairly certain XI deletes the old host files when hosts are deleted. If you were to delete 5 hosts you will not get an alert until a 6th new host is added.
if you change
  exit 0
  exit 0
it would solve this issue. My initial though was to query the database directly for a count of hosts and trigger off that but not knowing the table structure or MySQL or how to access this in a script this way was probably out of reach for me.
Grumpy Olde IT Guy
BanditBBS
Post by BanditBBS »
Yeah good catch on that. I'll modify my original post once I get to work. The only time this won't catch one is if somebody deletes and adds all within the same apply config!
JohnFLi
Post by JohnFLi »
that worked, thank you.
BanditBBS;
Your script works great as well. Thank you.
I will try to get it to check for deleted hosts as well.
BanditBBS
Post by BanditBBS »
Also, even a better idea would be to write a plugin to search the audit log for "New host inserted:" and display any outputs. it would have the new hostname after the : as well. I have no clue which DB the audit log is kept in. if someone in nagios wants to tell me the DB and table I'll attempt to write the plugin.
JohnFLi
Post by JohnFLi »
ok, i added some lines to notify when a host has been deleted
If you were able to include the name, that would be awesome.
#!/bin/bash
fi
# Compare counts
  exit 1
fi
if [ "$old_count" -gt "$current_count" ];then
  echo "Warning - Host has been Nuked!"
  exit 1
fi
  exit 0
The part I added is
  exit 1
fi
Dont forget to set permissions on the hostcount file so that Nagios can write to it ;)
