Error instaling fprobe on linux server
I am following this procedure to install fproble
http://assets.nagios.com/downloads/nagi ... alyzer.pdf
but I am getting this error at some point during the installation
checking for pcap.h in alternative location...
configure: error: pcap.h not found
- Box293
- Too Basu
Re: Error instaling fprobe on linux server
What distribution and version of linux are you running this on?
Linux-RHEL 6
Try to install fprobe manually.
# To start fprobe:
# To get fprobe boot start on reboot:
If this fails, run the following commands and show us the output:
yum install -y wget libpcap-devel gcc flex byacc bison make
cd /tmp
wget -O fprobe-1.1.tar.bz2 "http://downloads.sourceforge.net/project/fprobe/fprobe/1.1/fprobe-1.1.tar.bz2?r=http%3A%2F%2Fsourceforge.net%2Fprojects%2Ffprobe%2F&ts=1374682947&use_mirror=iweb"
tar xvf fprobe-1.1.tar.bz2
cd fprobe-1.1
./configure
make
make installCode: Select all
fprobe <NNA server>:<port>Code: Select all
echo "fprobe <NNA server>:<port>" >> /etc/rc.localCode: Select all
uname -a
cat /etc/*release
yum repolist -vBe sure to check out our Knowledgebase for helpful articles and solutions!
it fails on ./configure
# ./configure
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... none
checking for pthread_create in -lpthread... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for library containing sched_setscheduler... none required
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for inttypes.h... (cached) yes
checking pcap.h usability... no
checking pcap.h presence... no
checking for pcap.h... no
# ./configure
It's possible that you are missing the "libpcap-devel" package. To be honest with you, I haven't seen this issue before. However, I found a possible solution here:
http://stackoverflow.com/questions/1333 ... nd-linking
It references Fedora 17 but it may point you to the right direction. Hope this helps.
Nothing. did not helped
Run the following commands and show us the output:
uname -a
cat /etc/*release
yum repolist -v
yum list installed | grep pcapBe sure to check out our Knowledgebase for helpful articles and solutions!
root@nagmon:(04-22 17:31): /root
# uname -a
Linux nagmon 2.6.32-431.20.3.el6.x86_64 #1 SMP Fri Jun 6 18:30:54 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
# cat /etc/*release
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Red Hat Enterprise Linux Server release 6.5 (Santiago)
# yum repolist -v
yum list installed | grep pcapLoading "rhnplugin" plugin
Loading "refresh-packagekit" plugin
Config time: 0.069
This system is receiving updates from RHN Classic or RHN Satellite.
Looking for repo options for [main]
Looking for repo options for [rhel-x86_64-server-6]
Repo 'rhel-x86_64-server-6' setting option 'enabled' = '1'
Repo 'rhel-x86_64-server-6' setting option 'gpgcheck' = '1'
Repo 'rhel-x86_64-server-6' setting option 'timeout' = '120'
Yum Version: 3.2.29
Setting up Package Sacks
pkgsack time: 0.070
Repo-id : UBS-KITS-UBSLNX
Repo-name : Unix Business Servers Repository On ubslnx
Repo-updated : Wed Dec 19 14:11:47 2012
Repo-pkgs : 40
Repo-size : 631 M
Repo-baseurl : http://ubslnx.bose.com/pub/ubs-repository
Repo-expire : 3,600 second(s) (last: Wed Apr 22 17:23:52 2015)
Repo-excluded: 11
Repo-id : epel
Repo-name : Extra Packages for Enterprise Linux 6 - x86_64
Repo-revision: 1429720548
Repo-tags : binary-x86_64
Repo-updated : Wed Apr 22 12:39:01 2015
Repo-pkgs : 11,379
Repo-size : 11 G
Repo-metalink: https://mirrors.fedoraproject.org/metal ... rch=x86_64
Updated : Wed Apr 22 12:39:01 2015
Repo-baseurl : http://mirror.pnl.gov/epel/6/x86_64/ (42 more)
Repo-expire : 3,600 second(s) (last: Wed Apr 22 17:23:57 2015)
Repo-id : nagios-base
Repo-name : Nagios
Repo-revision: 1426806502
Repo-updated : Thu Mar 19 19:08:58 2015
Repo-pkgs : 121
Repo-size : 887 M
Repo-baseurl : http://repo.nagios.com/nagios/6/
Repo-expire : 3,600 second(s) (last: Wed Apr 22 17:24:03 2015)
Repo-id : nagiosxi-deps
Repo-name : Nagios XI Dependencies
Repo-revision: 1426806572
Repo-updated : Thu Mar 19 19:09:33 2015
Repo-pkgs : 28
Repo-size : 2.8 M
Repo-baseurl : http://repo.nagios.com/nagiosxi-deps/6/
Repo-id : rhel-x86_64-server-6
Repo-name : Red Hat Enterprise Linux Server (v. 6 for 64-bit x86_64)
Repo-updated : Wed Apr 22 06:21:07 2015
Repo-pkgs : 14,785
Repo-size : 25 G
Repo-baseurl : https://xmlrpc.rhn.redhat.com/XMLRPC/GE ... 4-server-6
Repo-id : rpmforge
Repo-name : RHEL 6Server - RPMforge.net - dag
Repo-updated : Thu Jul 10 21:46:59 2014
Repo-pkgs : 4,718
Repo-size : 2.2 G
Repo-baseurl : http://apt.sw.be/redhat/el6/en/x86_64/rpmforge
Repo-mirrors : http://apt.sw.be/redhat/el6/en/mirrors-rpmforge
Repo-expire : 3,600 second(s) (last: Wed Apr 22 17:24:04 2015)
repolist: 31,071
# yum list installed | grep pcap
libpcap.x86_64 14:1.4.0-1.20130826git2dbcaa1.el6
# uname -a
# cat /etc/*release
# yum repolist -v
Config time: 0.069
Yum Version: 3.2.29
pkgsack time: 0.070
Repo-pkgs : 40
Repo-size : 631 M
Repo-excluded: 11
Repo-id : epel
Repo-pkgs : 11,379
Repo-size : 11 G
Repo-name : Nagios
Repo-pkgs : 121
Repo-size : 887 M
Repo-pkgs : 28
Repo-size : 2.8 M
Repo-pkgs : 14,785
Repo-size : 25 G
Repo-id : rpmforge
Repo-pkgs : 4,718
Repo-size : 2.2 G
repolist: 31,071
Please issue the following:
Does your system find pcap.h? If not, please try to find it.
If you cannot find pcap.h, I believe that libpcap may not be installed properly. Try reinstalling it:
Does it exist now?
Best,
Jesse
whereis pcap.hCode: Select all
find /. -name pcap.hCode: Select all
yum -y remove libpcap*Code: Select all
yum -y install libpcap*Code: Select all
find /. -name pcap.hJesse
