can't read *log
ariarlet
can't read *log
Post by ariarlet »
I try to do a check to work remotely on windows . But when I want to read the log tells me I can not.
In the nsclient I have written
check_log3 = c:\perl.exe -p "ERROR" -l [path].log -c 1
and in the nagios i have written
check_nrpe -H (host) -p 5666 -c check_log3
what is the possible problem?
thank you
jolson
Attack Rabbit
Re: can't read *log
Post by jolson »
Are you running Nagios Core or Nagios XI? It looks like this post wound up in the wrong forum, and I would like to move it.
Twits Blog
ariarlet
Re: can't read *log
Post by ariarlet »
jolson wrote:Are you running Nagios Core or Nagios XI? It looks like this post wound up in the wrong forum, and I would like to move it.
NAgios XI
jdalrymple
Skynet Drone
Re: can't read *log
Post by jdalrymple »
ariarlet wrote:I try to do a check to work remotely on windows . But when I want to read the log tells me I can not.
thank you
In order to help we'll need more terse information.
What error did you receive specifically when you ran check_nrpe from the Nagios server?
ariarlet
Re: can't read *log
Post by ariarlet »
can't read [path].log
Re: can't read *log
Post by Box293 »
You may need to enable debug logging in NSClient++ and then restart NSClient++ service. Perform the test again and check the nsclient.log, post it here.
ariarlet
Re: can't read *log
Post by ariarlet »
how can i enable the debug logging?
thak you
jolson
Attack Rabbit
Re: can't read *log
Post by jolson »
ariarlet,
Are you typing in '[path].log' literally, or are you using an actual path? If that information is not sensitive, it could be useful to know which path you're trying to monitor.
What version of NSClient are you using? If you're using a recent version, you can enable “test and debug” mode with the following commands:
cd [NSClient path]
nscp stop
nscp test
If you're using an older version, replace 'nscp' with 'nsclient++' or whatever the executable may be called.
Twits Blog
ariarlet
Re: can't read *log
Post by ariarlet »
jolson wrote:ariarlet,
No, i don't writting this, I'm using a original path. xD
cd [NSClient path]
nscp stop
nscp test
My version is older and this does work
jolson
Attack Rabbit
Re: can't read *log
Post by jolson »
Open a command prompt as administrator and navigate to C:\Program Files\NSClient (or whatever directory your NSClient is in).
Next, type the below commands using the name of the NSClient executable - something like NSClient++.exe or nscp.exe:
<executable> stop
<executable> test
This should start NSClient in testing mode - try running the check from the Nagios server and let us know what appears in the command prompt. Thanks!
Twits Blog
