This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
JakeHatMacys
Posts: 281 Joined: Thu Sep 25, 2014 3:21 pm
Post
by JakeHatMacys » Thu Apr 23, 2015 12:04 pm
This is a new one for me:
Making all in plugins-scripts
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/plugins-scripts'
/bin/echo "#! #PERL# -w" | /bin/gawk -f ./subst > check_mysql_health
/bin/echo "# nagios: -epn" >> check_mysql_health
/bin/echo >> check_mysql_health
/bin/echo "my %ERRORS=( OK => 0, WARNING => 1, CRITICAL => 2, UNKNOWN => 3 );" >> check_mysql_health
/bin/echo "my %ERRORCODES=( 0 => 'OK', 1 => 'WARNING', 2 => 'CRITICAL', 3 => 'UNKNOWN' );" >> check_mysql_health
for m in Nagios/DBD/MySQL/Server/Instance/Innodb.pm Nagios/DBD/MySQL/Server/Instance/Myisam.pm Nagios/DBD/MySQL/Server/Instance/Replication.pm Nagios/DBD/MySQL/Server/Instance.pm Nagios/DBD/MySQL/Server.pm Nagios/DBD/MySQL/Cluster.pm Nagios/Extraopts.pm; do \
/bin/sed -e 's/^1;//g' < $m | /bin/gawk -f ./subst | /bin/grep -v "my %ERROR" >> check_mysql_health; \
done
if [ -d "/usr/local/nagios/libexec" ]; then \
for m in /usr/local/nagios/libexec/CheckMySQLHealthExt*.pm; do \
if [ -f $m ]; then \
/bin/echo found $m; \
fi \
done \
fi
/bin/cat check_mysql_health.pl | /bin/grep -v "^use Nagios" | /bin/grep -v "^my %ERROR" | /bin/gawk -f ./subst >> check_mysql_health
chmod +x check_mysql_health
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/plugins-scripts'
Making all in t
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/t'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/t'
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2'
make[1]: Nothing to be done for `all-am'.
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2'
Updating NRDP..
no crontab for nagios
Saving old crontab to /tmp/root.crontab.orig...
Removing XI cron jobs...
"-":4: bad minute
errors in crontab file, can't install.
JakeHatMacys on Fri Apr 24, 2015 12:23 pm, edited 1 time in total.
jdalrymple
Skynet Drone
Posts: 2620 Joined: Wed Feb 11, 2015 1:56 pm
Post
by jdalrymple » Thu Apr 23, 2015 2:54 pm
Weird...
what is the output of the following?
[root@localhost ~]# crontab -l -u root
JakeHatMacys
Post
by JakeHatMacys » Fri Apr 24, 2015 8:04 am
jdalrymple wrote: Weird...
[root@esu2v238 ~]# crontab -l -u root
5 0 * * * /usr/local/bin/nmon -x -f -t -s 900 -c 96 -m /archive/nmon_data 2>/dev/null
50 0 * * * /home/scripts/sys_info/prog/move_nmon_data.ksh 2>&1
50 2 * * 2 Shutting down ntpd: [ OK ]
Starting ntpd: [ OK ]
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Fri Apr 24, 2015 10:23 am
Let's double check the root crontab. Run the following command and show us the ouput:
You can also open it for editing by running (logged in as root):
and see if there is anything weird with the third line, line endings, formatting, etc.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
JakeHatMacys
Post
by JakeHatMacys » Fri Apr 24, 2015 12:23 pm
lmiltchev wrote: Let's double check the root crontab. Run the following command and show us the ouput:
[root@esu2v238 nagiosxi]# cat /var/spool/cron/root
jdalrymple
Skynet Drone
Post
by jdalrymple » Fri Apr 24, 2015 12:42 pm
At this point I'd remove (move) that crontab, it's icky. I'd like to see if it's a new thing or if that mess has been there.
Can you hook us up with your upgrade.log? Maybe PM it in case it has some weird stuff in it.
[root@localhost ~]# crontab -u root -l > ~/root.cronbak
[root@localhost ~]# crontab -u root -r
Then rerun the upgrade
JakeHatMacys
Post
by JakeHatMacys » Fri Apr 24, 2015 1:21 pm
jdalrymple wrote: At this point I'd remove (move) that crontab, it's icky. I'd like to see if it's a new thing or if that mess has been there.
PM'd the upgrade log and the upgrade completed without issue after I rand the crontab commands you had me run.
So thanks! no clue why that would've been messed up to begin with
Post
by lmiltchev » Fri Apr 24, 2015 2:10 pm
I am glad your issue has been resolved! Is is safe to lock this topic?
