email alert for Service Escalation not working
bosecorp
Post by bosecorp »
I am not receiving any service escalation alert
I have a service escalation that is associated to couple host with all the respective services. even though I have an active alert in nagios, I am not receiving any alert
jolson
Attack Rabbit
Re: email alert for Service Escalation not working
Post by jolson »
This document explains escalations, for your reference: http://assets.nagios.com/downloads/nagi ... ations.pdf
Would you please show us your escalation definitions?
cat /usr/local/nagios/etc/serviceescalations.cfg
cat /usr/local/nagios/etc/hostescalations.cfg
Twits Blog
bosecorp
Post by bosecorp »
Host escalation is fine. just service escalation
below is the info you ask for. I did followed the document. that is the document that I used to set this up
# cat /usr/local/nagios/etc/serviceescalations.cfg
# Service escalations configuration file
# Created by: Nagios Core Config Manager 2.2.2
# Date: 2015-04-24 13:32:27
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define serviceescalation {
host_name crgnas1.bose.com
service_description Check /vol/vol0,Check /vol/vol_Home1,Check /vol/vol_Share1,Check /vol/vol_Share2,Check Power Supply State,Check Power Supply State,Check Raid State,Check Temperature,Check Volumes,Ping
contact_groups CIS-ISCG-Tier1
first_notification 5
last_notification 120
notification_interval 30
escalation_period xi_timeperiod_24x7
escalation_options w,c,r,
host_name *
hostgroup_name *
service_description *
contacts dcops
first_notification 15
escalation_options w,u,c,r,
# END OF FILE
jolson
Attack Rabbit
Post by jolson »
Can you verify that at least five notifications have been sent out from one of your defined services? That is when CIS-ISCG-Tier1 should get an escalation notification.
Twits Blog
bosecorp
Post by bosecorp »
Yes, i do see the notifications
Let's clarify - you have five "regular" notifications sent out for these services but "escalated" notifications are not being sent afterwords, correct?
Can you show us the "State History" and "Notifications" reports for one of the "problem" services for the appropriate time period?
bosecorp
Post by bosecorp »
I am not utilizing regular notifications.
instead I am only using escalation. and escalation notifications are not being sent out
Also I just noticed that one particular service went down 23 min ago and there is not notification at all
What do you have defined for a regular notification then? Escalations rely on normal notifications being present, since each escalation takes over once a certain number of notifications have gone out.
bosecorp
Post by bosecorp »
small detail. Upss
so you mean to say that now I have to go and enable notification in each service? or can i do it in the service template
You can do it in the template or on a per-object basis, but yes you do need to have notifications enabled before escalations will work.
