.pdf reports error
btemple
.pdf reports error
Post by btemple »
When I try to run .pdf reports from notification or event log I receive the attached error. I checked the /tmp directory on a system that works as expected and the permissions are the same.
Re: .pdf reports error
What is the Nagios XI version that you are currently using? Are you using/forcing SSL? Go to Admin->Manage System Config and show us a screenshot of the page. Also, run the following commands and show us the output:
ifconfig
cat /etc/hosts
ls -ld /usr/local/nagiosxi
ls -ld /usr/local/nagiosxi/tmp
grep https /usr/local/nagiosxi/html/config.inc.php
/usr/bin/wkhtmltopdf -V
btemple
Post by btemple »
ran all the info you requested against both servers.
cat /etc/hosts was incorrect ....
Thank you and please close , reports are working as expected
abrist
Red Shirt
Post by abrist »
Awesome. Closing.
Have a good one!
