Domain Error!
gdolidze
Domain Error!
Post by gdolidze »
I used the domain wizard and it gives me this error
CRITICAL - Socket timeout after 10 seconds
while it does give me the status it remains red.
How do I make it green.
abrist
Red Shirt
Re: Domain Error!
Post by abrist »
What is the full command the check is running? (go to the CCM --> services --> click the "disk" icon for the service the question and post the relevant directive of the text file)
gdolidze
Re: Domain Error!
Post by gdolidze »
# Service configuration file
# Created by: Nagios Core Config Manager 2.3.2
# Date: 2015-04-27 15:38:27
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name cfjh.net
service_description Domain Expiration
use xiwizard_domain_expiration_service_v2
check_command check_xi_domain_v2!cfjh.net!-w 30!-c 15
max_check_attempts 5
check_interval 1440
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard domain_expiration
register 1
# END OF FILE
gdolidze
Re: Domain Error!
Post by gdolidze »
Gives me this OK - Domain cfjh.net will expire in 33 days (2015-05-30T13:22:45Z).
but its red and CRITICAL - Socket timeout after 10 seconds
abrist
Red Shirt
Re: Domain Error!
Post by abrist »
How long does it take to check?
time /usr/local/nagios/libexec/check_domain.php -d cfjh.net -w 30 -c 15
