1) Can these logs be redirected to its own log file?
2) Why is these errors coming out? I deleted the .xml and rrd files but it keeps on coming back.
Apr 27 22:05:23 nagiosprodxi1 rrdcached[26939]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiTHDB1_Clone_u05_-__u06.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiTHDB1_Clone_u05_-__u06.rrd: expected 2 data source readings (got 1) from 1430143208)
Apr 27 22:05:39 nagiosprodxi1 rrdcached[26939]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiTHDB1_Clone_u01_-__u03.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiTHDB1_Clone_u01_-__u03.rrd: expected 3 data source readings (got 1) from 1430143228)
Apr 27 22:13:47 nagiosprodxi1 ntpd[2367]: 0.0.0.0 c612 02 freq_set kernel -61.987 PPM
Apr 27 22:13:47 nagiosprodxi1 ntpd[2367]: 0.0.0.0 c61c 0c clock_step -0.486813 s
Apr 27 22:13:47 nagiosprodxi1 ntpd[2367]: 0.0.0.0 c615 05 clock_sync
Apr 27 22:13:48 nagiosprodxi1 ntpd[2367]: 0.0.0.0 c618 08 no_sys_peer
Apr 27 22:20:54 nagiosprodxi1 rrdcached[26939]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiDB2_Clone_v04_-__v06.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiDB2_Clone_v04_-__v06.rrd: illegal attempt to update using time 1430143528 when last update time is 1430144130 (minimum one second step))
Apr 27 22:22:03 nagiosprodxi1 rrdcached[26939]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiDB2_Clone_u05_-__u06.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/MXiBKP/Disk__MXiDB2_Clone_u05_-__u06.rrd: illegal attempt to update using time 1430143598 when last update time is 1430144190 (minimum one second step))
