Hi all.
I'm getting this error while I'm installing a fresh NNA on Centos 6.
'python: can't open file '/usr/local/nagiosna/bin/rc.py': [Errno 2] No such file or directory'
What could I have missed?
After intalling Centos 6 I updated the system and then followed NNA installation instructions.
Thank you,
NAGIOS NA Install Error
Re: NAGIOS NA Install Error
Can you show us your 'history'? It's possible that there was a missed step. Feel free to scrub the history for sensitive information.
It's also possible that selinux is still on, which could interfere with installation/functionality:
historyCode: Select all
sestatus-
botswanamtc
I Installed CENTOS 6 and ran an update, then installed NNA. I got the error at the end of installation process.
I have just diabled selinux but the error persist.
Thank you.
Thank you.
You will likely need to disable selinux before installing Nagios Network Analyzer - I've seen that cause problems before. Any chance you could start fresh and disable selinux prior to running the installer?
