We have a few checks implemented using the Oracle Query plugin which return counts from Db tables e.g.
select count(*) from esjkeprd.ej_bulk_comm_send ebcs, esjkeprd.ej_bulk_communication ebc where ebc.id=ebcs.communication_id and (ebcs.is_sent!='y' and ebcs.is_sent!='f') and ebcs.is_ready!='f' and ebc.method_id=1328: 2604
The issue we have is that our customer has a bulk send function and can send out thousands of records in one batch, the fact there is a big number outstanding is not an issue as it will eventually clear.
Is there a way we can configure Nagios to alert if the number returned is the same more than once i.e. the queue is not clearing?
Alert when Value not changed
jdalrymple
- Skynet Drone
Re: Alert when Value not changed
By default Nagios plugins are without state. It can be pretty easy to add with a wrapper though:
wrapper.sh
wrapper.sh
#!/bin/bash
tmpfile="/tmp/nagioscheckfoo.tmp"
nrpe="/usr/local/nagios/libexec/check_nrpe"
check="$1"
newrun="$($check | sed 's/[^0-9]*//')"
oldrun="$(head -1 $tmpfile)"
echo $newrun > $tmpfile
if [ "$newrun" -eq "$oldrun" ]; then
output=2
status="CRITICAL - Nothing has changed"
else
output=0
status="OK - The data seems to have changed"
fi
echo $status
exit $outputCode: Select all
[root@localhost libexec]# ./wrapper.sh '/usr/local/nagios/libexec/check_dummy 0 12345'
[root@localhost libexec]# ./wrapper.sh '/usr/local/nagios/libexec/check_dummy 0 12346'
OK - The data seems to have changedRe: Alert when Value not changed
Excellent, thanks will give that a try
Let us know if this works for you or if you have any follow up questions.
jdalrymple
- Skynet Drone
Happy to help - that's the beauty of Nagios. If it doesn't already do what you want, it's usually pretty easy to change its behavior.
Let us know if this doesn't work out for you.
