Nagios xi monitoring NNA
rashid2014
Post by rashid2014 »
hello
i want to monitor NNA with Nagios XI. i use Nagios Network Analyzer Monitoring Wizard but it said "Failed connect to API.".
what API does i mean? please
ssax
Dreams In Code
Re: Nagios xi monitoring NNA
Post by ssax »
Did you enter the proper API key from your NNA server? You can grab it by clicking on your username in the top right corner of NNA.
First you need to login to your Network Analyzer system.
Click on the username on the top right of the screen.
On this screen, you can get the API key. If it is blank, generate one.
Next, login to Nagios XI and click on Admin > Manage Components, Scroll down to "Nagios Network Analyzer Integration" and click on the Edit Settings icon.
Fill in a name, put in the IP address of your NNA server and paste in the API key. If you have SSL enabled, check that box.
Apply the settings.
Make sure the firewall is disabled on the NNA server.
rashid2014
thanks!!!
it is ok
ssax
Dreams In Code
Post by ssax »
Can we mark this thread as resolved and lock the topic?
