Nagiosxi Client Installation
lmichel
Post by lmichel »
Couple of Questions
1. I am trying to install the NRPE agent on a RHEL 6.6 server and it is throwing a Permission denied error every time i run the ./fullinstall script. Does anyone know why?
2. I have a bunch of Servers running Solaris 11 X86 I need to monitor, but from the configure wizard option when I clicked on Solaris it only shows Solaris 10. Can Nagios xi monitor Solaris 11 servers?
if yes, how do I go about doing that?
lmichel
Re: Nagiosxi Client Installation
Post by lmichel »
please ignore step 1.
another issue I am now having is that every time I tried to configure a wizard, it takes forever until the process dies.
when I am done creating the wizard, the following follows:
1. Configuration submitted for processing...
2. Waiting for configuration verification --- --> that one never ends. it has been running for over an hour.
the configuration wizard i am trying to create is to monitor Linux servers.
What version of XI are you using?
lmichel
Post by lmichel »
I am using the 60 day trial version of the enterprise.
I was more referring to the release version, such as 2014R2.7 which is most likely what you are using if you are in the trial.
Please run the following as root from the command line, and post the output:
cd /usr/local/nagiosxi/scripts/
./reconfigure_nagios.sh | tail -20
lmichel
Post by lmichel »
[root@uls-gzlinux-01 scripts]# ./reconfigure_nagios.sh | tail -20
2015-04-30 11:53:16 (120 KB/s) - ânagiosql.import.monitoringâ saved [15828]
--2015-04-30 11:53:16-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... connected.
Length: unspecified [text/html]
Saving to: ânagiosql.import.monitoringâ
[ <=> ] 15,717 --.-K/s in 0.1s
2015-04-30 11:53:16 (115 KB/s) - ânagiosql.import.monitoringâ saved [15717]
[ <=> ] 15,586 --.-K/s in 0.1s
2015-04-30 11:53:17 (115 KB/s) - ânagiosql.import.monitoringâ saved [15586]
--2015-04-30 11:53:17-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 15,470 --.-K/s in 0.1s
2015-04-30 11:53:17 (113 KB/s) - ânagiosql.import.monitoringâ saved [15470]
[ <=> ] 15,354 --.-K/s in 0.1s
2015-04-30 11:53:17 (120 KB/s) - ânagiosql.import.monitoringâ saved [15354]
[ <=> ] 15,238 --.-K/s in 0.1s
2015-04-30 11:53:17 (117 KB/s) - ânagiosql.import.monitoringâ saved [15238]
[ <=> ] 15,122 --.-K/s in 0.1s
2015-04-30 11:53:17 (114 KB/s) - ânagiosql.import.monitoringâ saved [15122]
[ <=> ] 15,015 87.0KB/s in 0.2s
2015-04-30 11:53:18 (87.0 KB/s) - ânagiosql.import.monitoringâ saved [15015]
--2015-04-30 11:53:18-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 14,879 --.-K/s in 0.1s
2015-04-30 11:53:18 (101 KB/s) - ânagiosql.import.monitoringâ saved [14879]
Saving to: ânagiosql.loginâ
[ <=> ] 11,252 --.-K/s in 0.008s
2015-04-30 11:53:18 (1.36 MB/s) - ânagiosql.loginâ saved [11252]
Saving to: ânagiosql.export.monitoringâ
[ <=> ] 14,778 48.9KB/s in 0.3s
2015-04-30 11:53:19 (48.9 KB/s) - ânagiosql.export.monitoringâ saved [14778]
Checked 7 contacts.
Checked 2 contact groups.
Checked 118 commands.
Checked 13 time periods.
Checked 0 host escalations.
Checked 5 hosts
Checked 0 host dependencies
Checked 13 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
Post by Box293 »
That output you sent looks OK. Out of curiosity, after running that are the Linux servers now being monitored?
Can you make sure your timezone has been selected and applied:
Admin > System Config > Manage System Config
Select the correct UTC timezone and click Update Settings
Does the config wizard work now?
lmichel
Post by lmichel »
nope it still does not work and I am unable to monitor anything.
lmichel
Post by lmichel »
here is what I did:
1. I clicked on configure
2. I selected Linux Server
3. I clicked on Next
4. I typed in the IP of the server I want to monitor and selected RedHat Enterprise as the Linux Distribution
I have been waiting for over two hours for this thing to be completed but it never did.
jolson
Attack Rabbit
Post by jolson »
Let's switch to the nagios user and run this process again.
su - nagios
Twits Blog
