Alerts no longer fireing
I loaded in about 200 or so alerts into nagios logserver. Somewhere along the line they stopped fireing. They will fire if i manually trigger them.
I have the alerts set to check every 5 minues for a loop back of 60 minutes
they all stopped firing at about the same time
Wed, 29 Apr 2015 17:03:02 -0400
I'm running Nagios Log Server • 2015R1.4
Thank you
Thank you
Re: Alerts no longer fireing
If you do a 'follow tail' on jobs.log, do you see the 'run_alerts' command run every minute?
Every minute or so you should see:
If you do not see the above, you'll need to reset your jobs from the command subsystem page.
I would also like a tail of your cron log:
Let me know - thanks!
tail -f /usr/local/nagioslogserver/var/jobs.logCode: Select all
Running command run_alerts with args ' ' for job id: run_all_alertsI would also like a tail of your cron log:
tail -n20 /var/log/cronRe: Alerts no longer fireing
jolson wrote:If you do a 'follow tail' on jobs.log, do you see the 'run_alerts' command run every minute?Every minute or so you should see:Code: Select all
tail -f /usr/local/nagioslogserver/var/jobs.logIf you do not see the above, you'll need to reset your jobs from the command subsystem page.Code: Select all
I would also like a tail of your cron log:Let me know - thanks!Code: Select all
The jobs.log is a 0 byte file
[root@pnagios05lxv ~]# tail -n20 /var/log/cron
Apr 30 14:40:01 pnagios05lxv CROND[2834]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:40:01 pnagios05lxv CROND[2835]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:41:01 pnagios05lxv CROND[2926]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:41:01 pnagios05lxv CROND[2928]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:42:01 pnagios05lxv CROND[3069]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:42:01 pnagios05lxv CROND[3070]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:43:01 pnagios05lxv CROND[3170]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:43:01 pnagios05lxv CROND[3172]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:44:01 pnagios05lxv CROND[3269]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:44:01 pnagios05lxv CROND[3271]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:45:01 pnagios05lxv CROND[3369]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:45:01 pnagios05lxv CROND[3370]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:46:01 pnagios05lxv CROND[3470]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:46:01 pnagios05lxv CROND[3471]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:47:01 pnagios05lxv CROND[3605]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:47:01 pnagios05lxv CROND[3606]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:48:01 pnagios05lxv CROND[3703]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:48:01 pnagios05lxv CROND[3705]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Apr 30 14:49:01 pnagios05lxv CROND[3805]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Apr 30 14:49:01 pnagios05lxv CROND[3807]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogser ver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Jobs.log is truncated very often, which is why I suggested a 'follow tail' as opposed to a regular tail - I should have mentioned that in my original post. I would like to see if your alert jobs are firing.The jobs.log is a 0 byte file
Based on the looks of your cron log, the jobs are firing properly - but I would like you to verify that.
Is that space in "nagioslogser ver" in your /etc/cron.d/nagioslogserver file as well or is it a typo in your post?
here's what i'm seeing from the tailjolson wrote:Jobs.log is truncated very often, which is why I suggested a 'follow tail' as opposed to a regular tail - I should have mentioned that in my original post. I would like to see if your alert jobs are firing.The jobs.log is a 0 byte file
[root@pnagios05lxv ~]# tail -f /usr/local/nagioslogserver/var/jobs.log
Processed 0 node jobs.
Processed 0 global jobs.
tail: /usr/local/nagioslogserver/var/jobs.log: file truncated
It looks like your alert jobs aren't coming in. Try resetting your jobs from the Command Subsystem:
jolson wrote:It looks like your alert jobs aren't coming in. Try resetting your jobs from the Command Subsystem:
ok cool that looks like it got it running again. Do you know what may have caused this and is there a way to have this alert if these jobs are not running?
Glad to hear you're up and running again!
Typically this doesn't happen often, and I'm not sure what may have caused it in your case. Occasionally a Nagios Log Server update breaks the jobs system for whatever reason, and a job reset fixes the issue as it did in this case. Did you upgrade NLS recently? Anything notable that you might have changed before the alerts stopped triggering?
Another method may be monitoring the maillog of the server in question for activity - if mail stops being sent, that's an indication the job server may have detached.
I understand that the above methods are a little patched together, but there is not currently a mechanism in Nagios Log Server for detecting this - I can definitely file a feature request on your behalf if you'd like me to.
Best,
Jesse
One method that I can think of is to create an alert that always fires - have it send an email to some mailbox every minute. If the emails were to stop coming in automatically, that's an indication the job server may have detached.Do you know what may have caused this and is there a way to have this alert if these jobs are not running?
Best,
Jesse
jolson wrote:Glad to hear you're up and running again!
Typically this doesn't happen often, and I'm not sure what may have caused it in your case. Occasionally a Nagios Log Server update breaks the jobs system for whatever reason, and a job reset fixes the issue as it did in this case. Did you upgrade NLS recently perhaps? Anything notable that you might have changed before the alerts stopped triggering?
Best,
Jesse
no upgrade recently. But I did add more memory to the system and reboot. The timing almost lines up.
Thanks for the tip. I think I might just write a nagios plugin or a check_mk check to monitor this. I don't think monitoring the maillog will work for me as we arn't sending any e-mail notifications just NDRP to our nagios dashboard.
