How to temporarily disable Event Handlers during maintenance
skynardo
Post by skynardo »
Running Nagios XI 2014R2.5 - I was doing some testing with scheduled downtime and it seems that all this does is stop notifications. I am currently using Event Handlers to forward specific alerts (production/critical) to a 3rd party Event console that is monitored by our Data Center. We have a large ERRATA update happening this weekend that I would like to not generate a bunch of alerts and tickets on our integrated systems. The service checks running on the clients are all passive using nrds and I don't see an option to disable/ignore passive checks. Does anyone have any suggestions about how I could do this. I suppose I could update my templates to remove the EventHandlers during the update, though this is un-handy and would rather be able to schedule something by host group.
jdalrymple
Skynet Drone
Re: How to temporarily disable Event Handlers during mainten
Post by jdalrymple »
The community solution to this is to use the $SERVICEDOWNTIME$ and/or $HOSTDOWNTIME$ macros to your event handler and use logic to prevent them from running. There is no solution intrinsic to Nagios scheduled downtimes.
A quick way to disable Event Handlers is to click on Admin > Monitoring Engine Status under the System Information menu and disable the Event Handlers.
FYI, this will disable all Event Handlers.
Post by Box293 »
You could globally disable all Active Host and Service checks via Admin > System Information > Monitoring Engine Status > Monitoring Engine Process.
Otherwise you may need to do that on a per host and service level individually.
Another option is to create Escalations that prevent the execution of checks in the event of the master service going down.
skynardo
Post by skynardo »
jdalrymple wrote:The community solution to this is to use the $SERVICEDOWNTIME$ and/or $HOSTDOWNTIME$ macros to your event handler and use logic to prevent them from running. There is no solution intrinsic to Nagios scheduled downtimes.
This sounds like a good solution. If I modify my Event Handlers to evaluate SERVICEDOWNTIMES and HOSTDOWNTIMES, I can have them simply exit if not zero? And these Macros would be set via "schedule downtime for all hosts/services in this hostgroup" command ?
Thanks to all that responded. If I don't find time to test this out will use one of the alternative suggestions.
jdalrymple
Skynet Drone
skynardo wrote:This sounds like a good solution. If I modify my Event Handlers to evaluate SERVICEDOWNTIMES and HOSTDOWNTIMES, I can have them simply exit if not zero? And these Macros would be set via "schedule downtime for all hosts/services in this hostgroup" command ?.
You got it. Let us know if that doesn't work for you.
skynardo
Post by skynardo »
This seems to be working fine. I updated my event handlers and tested. Thanks for the help!
