Internal Server Error When Attempting to Schedule Downtime
I am fairly new to Nagios and have recently installed 4.08 running under Red Hat 6.6.
Overall, things are working well. However, when I attempt to schedule downtown on a server, or Post a Notification (or a few other tasks), I get the following error from Apache:
The server encountered an internal error or misconfiguration and was unable to complete your request.
And the Apache error_log shows:
Premature end of script headers: cmd.cgi, referer: http://myserver/nagios/cgi-bin/extinfo. ... ost=myhost
I have tried several of the tricks posted to this forum from folks with similar issues. None have worked so far.
For Example:
[root@myserver httpd]# sestatus
SELinux status: disabled
Any additional information or other things to try would be greatly appreciated.
For Example:
Re: Internal Server Error When Attempting to Schedule Downti
Could you run the following and post the output here?
ll /usr/local/nagios/var/rw/
ll /usr/local/nagios/sbinBe sure to check out our Knowledgebase for helpful articles and solutions!
# ll /usr/local/nagios/var/rw/
total 0
prw-rw---- 1 nagios nagcmd 0 May 4 13:15 nagios.cmd
srw-rw---- 1 nagios nagcmd 0 May 4 13:15 nagios.qh
# ll /usr/local/nagios/sbin
total 4920
-rwxrwxr-x. 1 nagios nagios 367240 Apr 13 13:56 archivejson.cgi
-rwxrwxr-x. 1 nagios nagios 352816 Apr 13 13:56 avail.cgi
-rwxrwxr-x 1 nagios nagios 356808 Apr 13 13:56 cmd.cgi
-rwxrwxr-x. 1 nagios nagios 351496 Apr 13 13:56 config.cgi
-rwxrwxr-x. 1 nagios nagios 353344 Apr 13 13:56 extinfo.cgi
-rwxrwxr-x. 1 nagios nagios 284512 Apr 13 13:56 history.cgi
-rwxrwxr-x. 1 nagios nagios 284272 Apr 13 13:56 notifications.cgi
-rwxrwxr-x. 1 nagios nagios 357120 Apr 13 13:56 objectjson.cgi
-rwxrwxr-x. 1 nagios nagios 283664 Apr 13 13:56 outages.cgi
-rwxrwxr-x. 1 nagios nagios 284384 Apr 13 13:56 showlog.cgi
-rwxrwxr-x. 1 nagios nagios 353064 Apr 13 13:56 status.cgi
-rwxrwxr-x. 1 nagios nagios 351184 Apr 13 13:56 statusjson.cgi
-rwxrwxr-x. 1 nagios nagios 288040 Apr 13 13:56 statuswml.cgi
-rwxrwxr-x. 1 nagios nagios 284144 Apr 13 13:56 statuswrl.cgi
-rwxrwxr-x. 1 nagios nagios 298288 Apr 13 13:56 summary.cgi
-rwxrwxr-x. 1 nagios nagios 284552 Apr 13 13:56 tac.cgi
total 0
total 4920
Could you run these too? I want to check to see if the nagcmd group is setup.
grep nag /etc/passwd
grep nag /etc/groupBe sure to check out our Knowledgebase for helpful articles and solutions!
# grep nag /etc/passwd
nagios
505:506::/home/nagios:/bin/bash
nagiosadmin
506:508::/home/nagiosadmin:/bin/bash
# grep nag /etc/group
nagios
506:apache,nagiosadmin
nagcmd
507:nagios,nagiosadmin,apache
nagiosadmin
508:
nagios
nagiosadmin
nagios
nagcmd
nagiosadmin
jdalrymple
- Skynet Drone
This all looks pretty workable. Is there anything in the general vicinity of your error_log as you mentioned - or just that 1 line?
Did you compile from source? If so there may be some stuff in your logs that's useful there? Maybe something broke silently during compile time?bfortman wrote:And the Apache error_log shows:Code: Select all
Premature end of script headers: cmd.cgi, referer: http://myserver/nagios/cgi-bin/extinfo.cgi?type=1&host=myhost
The Apache access_log throws this single line:
nagiosadmin [04/May/2015:14:57:58 -0500] "GET /nagios/cgi-bin/cmd.cgi?cmd_typ=159&host=myhost HTTP/1.1" 500 608 "http://myserver/nagios/cgi-bin/extinfo. ... ost=myhost" "Mozilla/5.0 (Windows NT 6.1; WOW64; rv:36.0) Gecko/20100101 Firefox/36.0"
Even in debug mode logging, the apache error_log only throws the one line "Premature end of script..."
I did compile Nagios Core from source. I have attached the output from "make all". There are a few warnings, but nothing appears to have broken during the compile.
I've narrowed down the Internal Server Errors to these specific activities:
Hosts - Send custom host notification
Hosts - Schedule downtime for this host
Hosts - Schedule downtime for all the services on this host
Downtime - Scheduled host downtime
Downtime - Schedulled service downtime
All other functionality works ok (with the exception of Map, Trends, and Histogram which I have not yet compiled separately)
make.out.txt- Output results of "make all"
- (12.52 KiB) Downloaded 340 times
I'm not seeing anything in your make log either.
Please post the output of these commands:
ls -l /usr/local/nagios/var
ls -l /usr/local/nagios-
jdalrymple
- Skynet Drone
I assume based upon the error that this happens when you are trying to get to the schedule downtime page?
What are the results of http://myserver/nagios/cgi-bin/extinfo.cgi
How about http://myserver/nagios/cgi-bin/cmd.cgi
I expect both of those to work fine based upon what you've shared so far. Would you care to gzip up your cgis and send them my way? Unless you did any mad customization (which would no doubt be the source - no pun intended - of your problem) there should be no sensitive information. I'd love to just drop them on my 6.6 machine and see if they CGIs work properly here.
The account and settings do look like they work. Lets check a few more things. Run these commands.
grep nagiosadmin /usr/local/nagios/etc/cgi.cfg
cat /etc/httpd/conf.d/nagios.conf
