Alert if Memory on a Process Drops Below a Specified Thresho
shorn
Post by shorn »
I know it's possible to monitor a Windows process and it's memory usage and alert when it exceeds a certain threshold. However it is possible to alert when the memory usage of a process falls below a certain threshold?
Cheers,
Simon
Re: Alert if Memory on a Process Drops Below a Specified Thr
What is the plugin that you are currently using to monitor a windows process and it's memory usage? Can you show us the actual command that you run from the command line, along with the output of it?
