Nagios LS is not displaying new logs anymore on the web interface. I know logs are still sent and received (if I stop the logstash one of my device starts complaining that the destination is not available).
When I reboot one of our log servers (we have a 2 nodes cluster), it sometimes process a bulk of logs, then does nothing anymore...
I can see the following errors in the elasticsearch logs, I don't know if it might be related. All the errors are from the source "vmwnagioslog1", which is the Nagios LS itself (well, on of them).
[2015-05-05 13:55:24,383][DEBUG][action.bulk ] [bed86ca0-2b78-4d69-a1da-0e63846227a8] [logstash-2015.05.05][0] failed to execute bulk item (index) index {[logstash-2015.05.05][syslog][Bt0RskshSkGn-oEoZm0aXQ], source[{"message":" apache : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/elasticsearch status","@version":"1","@timestamp":"2015-05-05T11:55:23.000Z","type":"syslog","host":"127.0.0.1","priority":85,"timestamp":"May 5 13:55:23","logsource":"vmwnagioslog1","program":"sudo","severity":5,"facility":10,"facility_label":"security/authorization","severity_label":"Notice"}]}
org.elasticsearch.index.mapper.MapperParsingException: failed to parse [timestamp]
at org.elasticsearch.index.mapper.core.AbstractFieldMapper.parse(AbstractFieldMapper.java:414)
at org.elasticsearch.index.mapper.object.ObjectMapper.serializeValue(ObjectMapper.java:648)
at org.elasticsearch.index.mapper.object.ObjectMapper.parse(ObjectMapper.java:501)
at org.elasticsearch.index.mapper.DocumentMapper.parse(DocumentMapper.java:534)
at org.elasticsearch.index.mapper.DocumentMapper.parse(DocumentMapper.java:483)
at org.elasticsearch.index.shard.service.InternalIndexShard.prepareCreate(InternalIndexShard.java:376)
at org.elasticsearch.action.bulk.TransportShardBulkAction.shardIndexOperation(TransportShardBulkAction.java:430)
at org.elasticsearch.action.bulk.TransportShardBulkAction.shardOperationOnPrimary(TransportShardBulkAction.java:158)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$AsyncShardOperationAction.performOnPrimary(TransportShardReplicationOperationAction.java:522)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$AsyncShardOperationAction$1.run(TransportShardReplicationOperationAction.java:421)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.elasticsearch.index.mapper.MapperParsingException: failed to parse date field [May 5 13:55:23], tried both date format [dateOptionalTime], and timestamp number with locale []
at org.elasticsearch.index.mapper.core.DateFieldMapper.parseStringValue(DateFieldMapper.java:610)
at org.elasticsearch.index.mapper.core.DateFieldMapper.innerParseCreateField(DateFieldMapper.java:538)
at org.elasticsearch.index.mapper.core.NumberFieldMapper.parseCreateField(NumberFieldMapper.java:223)
at org.elasticsearch.index.mapper.core.AbstractFieldMapper.parse(AbstractFieldMapper.java:404)
... 12 more
[color=#FF0000][b]Caused by: java.lang.IllegalArgumentException: Invalid format: "May 5 13:55:23"[/b][/color]
at org.elasticsearch.common.joda.time.format.DateTimeFormatter.parseMillis(DateTimeFormatter.java:754)
at org.elasticsearch.index.mapper.core.DateFieldMapper.parseStringValue(DateFieldMapper.java:604)
... 15 more
