My backup wasn't working for three or so weeks. Although, it's scheduled to run every night. And then passed couple of days it decided to work again.
What I have noticed, is that issues occur in the beginning of the month. Is it possible something with the underlying scheduling?
Here is reference to another thread that I had opened in regards my issues with backup I had before
http://support.nagios.com/forum/viewtop ... 37&t=31171
NLS Backup works inconsistently
Re: NLS Backup works inconsistently
stecino,
The most common cause of your backups not firing is an improper/corrupt backup. If a backup did not fully complete, the backup process will stall. For instance, if the 'Delete backups older than' setting is set to three days, you may get a corrupt backup on day one - but on day 4 they may start working again because the corrupt backup can be skipped or deleted. This could explain some of the weirdness you are encountering. I will setup a test repository on my end to see if I have any issues with end of the month backups.
In the meantime, we may be able to get this working using a similar procedure as last time - tailing jobs.log and forcing a backup run to see if there are any errors.
Force the 'backup and maintenance' command from the Web GUI.
tail -f /usr/local/nagioslogserver/var/jobs.logRe: NLS Backup works inconsistently
Forced a backupjolson wrote:stecino,
Force the 'backup and maintenance' command from the Web GUI.Code: Select all
Processed 0 node jobs.
Processed 0 global jobs.
tail: /usr/local/nagioslogserver/var/jobs.log: file truncated
Running command do_maintenance with args ' ' for job id: backup_maintenance
2015-05-22 14:04:02,920 INFO Job starting...
2015-05-22 14:04:02,928 INFO Beginning BLOOM operations...
2015-05-22 14:04:02,959 INFO Attempting to disable bloom filter for index logstash-2015.04.23.
2015-05-22 14:04:03,381 INFO logstash-2015.04.23: Successfully bloom filter disabled.
2015-05-22 14:04:03,382 INFO Attempting to disable bloom filter for index logstash-2015.04.24.
2015-05-22 14:04:03,820 INFO logstash-2015.04.24: Successfully bloom filter disabled.
2015-05-22 14:04:03,820 INFO Attempting to disable bloom filter for index logstash-2015.04.25.
2015-05-22 14:04:04,193 INFO logstash-2015.04.25: Successfully bloom filter disabled.
2015-05-22 14:04:04,194 INFO Attempting to disable bloom filter for index logstash-2015.04.26.
2015-05-22 14:04:04,581 INFO logstash-2015.04.26: Successfully bloom filter disabled.
2015-05-22 14:04:04,582 INFO Attempting to disable bloom filter for index logstash-2015.04.27.
2015-05-22 14:04:04,971 INFO logstash-2015.04.27: Successfully bloom filter disabled.
2015-05-22 14:04:04,971 INFO Attempting to disable bloom filter for index logstash-2015.04.28.
2015-05-22 14:04:05,340 INFO logstash-2015.04.28: Successfully bloom filter disabled.
2015-05-22 14:04:05,340 INFO Attempting to disable bloom filter for index logstash-2015.04.29.
2015-05-22 14:04:05,717 INFO logstash-2015.04.29: Successfully bloom filter disabled.
2015-05-22 14:04:05,718 INFO Attempting to disable bloom filter for index logstash-2015.04.30.
2015-05-22 14:04:06,083 INFO logstash-2015.04.30: Successfully bloom filter disabled.
2015-05-22 14:04:06,083 INFO Attempting to disable bloom filter for index logstash-2015.05.01.
2015-05-22 14:04:06,433 INFO logstash-2015.05.01: Successfully bloom filter disabled.
2015-05-22 14:04:06,433 INFO Attempting to disable bloom filter for index logstash-2015.05.02.
2015-05-22 14:04:06,803 INFO logstash-2015.05.02: Successfully bloom filter disabled.
2015-05-22 14:04:06,804 INFO Attempting to disable bloom filter for index logstash-2015.05.03.
2015-05-22 14:04:07,183 INFO logstash-2015.05.03: Successfully bloom filter disabled.
2015-05-22 14:04:07,184 INFO Attempting to disable bloom filter for index logstash-2015.05.04.
2015-05-22 14:04:07,535 INFO logstash-2015.05.04: Successfully bloom filter disabled.
2015-05-22 14:04:07,536 INFO Attempting to disable bloom filter for index logstash-2015.05.05.
2015-05-22 14:04:07,931 INFO logstash-2015.05.05: Successfully bloom filter disabled.
2015-05-22 14:04:07,932 INFO Attempting to disable bloom filter for index logstash-2015.05.06.
2015-05-22 14:04:08,302 INFO logstash-2015.05.06: Successfully bloom filter disabled.
2015-05-22 14:04:08,303 INFO Attempting to disable bloom filter for index logstash-2015.05.07.
2015-05-22 14:04:08,670 INFO logstash-2015.05.07: Successfully bloom filter disabled.
2015-05-22 14:04:08,671 INFO Attempting to disable bloom filter for index logstash-2015.05.08.
2015-05-22 14:04:09,044 INFO logstash-2015.05.08: Successfully bloom filter disabled.
2015-05-22 14:04:09,044 INFO Attempting to disable bloom filter for index logstash-2015.05.09.
2015-05-22 14:04:09,420 INFO logstash-2015.05.09: Successfully bloom filter disabled.
2015-05-22 14:04:09,420 INFO Attempting to disable bloom filter for index logstash-2015.05.10.
2015-05-22 14:04:09,791 INFO logstash-2015.05.10: Successfully bloom filter disabled.
2015-05-22 14:04:09,792 INFO Attempting to disable bloom filter for index logstash-2015.05.11.
2015-05-22 14:04:10,152 INFO logstash-2015.05.11: Successfully bloom filter disabled.
2015-05-22 14:04:10,152 INFO Attempting to disable bloom filter for index logstash-2015.05.12.
2015-05-22 14:04:10,532 INFO logstash-2015.05.12: Successfully bloom filter disabled.
2015-05-22 14:04:10,533 INFO Attempting to disable bloom filter for index logstash-2015.05.13.
2015-05-22 14:04:10,908 INFO logstash-2015.05.13: Successfully bloom filter disabled.
2015-05-22 14:04:10,909 INFO Attempting to disable bloom filter for index logstash-2015.05.20.
2015-05-22 14:04:11,111 INFO logstash-2015.05.20: Successfully bloom filter disabled.
2015-05-22 14:04:11,112 INFO Attempting to disable bloom filter for index logstash-2015.05.21.
2015-05-22 14:04:11,492 INFO logstash-2015.05.21: Successfully bloom filter disabled.
2015-05-22 14:04:11,493 INFO logstash-2015.05.22 is within the threshold period (1 days).
2015-05-22 14:04:11,493 INFO logstash-2015.05.23 is within the threshold period (1 days).
2015-05-22 14:04:11,493 INFO DISABLE BLOOM FILTER index operations completed.
2015-05-22 14:04:11,494 INFO Done in 0:00:08.604728.
2015-05-22 14:04:11,827 INFO Job starting...
2015-05-22 14:04:11,827 INFO Default timeout of 30 seconds is too low for command OPTIMIZE. Overriding to 21,600 seconds (6 hours).
2015-05-22 14:04:11,834 INFO Beginning OPTIMIZE operations...
2015-05-22 14:04:11,865 INFO Attempting to optimize index logstash-2015.04.23.
2015-05-22 14:04:11,908 INFO Job starting...
2015-05-22 14:04:11,915 INFO Beginning CLOSE operations...
2015-05-22 14:04:11,945 INFO logstash-2015.04.23 is within the threshold period (30 days).
2015-05-22 14:04:11,945 INFO logstash-2015.04.24 is within the threshold period (30 days).
2015-05-22 14:04:11,945 INFO logstash-2015.04.25 is within the threshold period (30 days).
2015-05-22 14:04:11,946 INFO logstash-2015.04.26 is within the threshold period (30 days).
2015-05-22 14:04:11,946 INFO logstash-2015.04.27 is within the threshold period (30 days).
2015-05-22 14:04:11,946 INFO logstash-2015.04.28 is within the threshold period (30 days).
2015-05-22 14:04:11,947 INFO logstash-2015.04.29 is within the threshold period (30 days).
2015-05-22 14:04:11,947 INFO logstash-2015.04.30 is within the threshold period (30 days).
2015-05-22 14:04:11,947 INFO logstash-2015.05.01 is within the threshold period (30 days).
2015-05-22 14:04:11,948 INFO logstash-2015.05.02 is within the threshold period (30 days).
2015-05-22 14:04:11,948 INFO logstash-2015.05.03 is within the threshold period (30 days).
2015-05-22 14:04:11,948 INFO logstash-2015.05.04 is within the threshold period (30 days).
2015-05-22 14:04:11,949 INFO logstash-2015.05.05 is within the threshold period (30 days).
2015-05-22 14:04:11,949 INFO logstash-2015.05.06 is within the threshold period (30 days).
2015-05-22 14:04:11,949 INFO logstash-2015.05.07 is within the threshold period (30 days).
2015-05-22 14:04:11,950 INFO logstash-2015.05.08 is within the threshold period (30 days).
2015-05-22 14:04:11,950 INFO logstash-2015.05.09 is within the threshold period (30 days).
2015-05-22 14:04:11,950 INFO logstash-2015.05.10 is within the threshold period (30 days).
2015-05-22 14:04:11,951 INFO logstash-2015.05.11 is within the threshold period (30 days).
2015-05-22 14:04:11,951 INFO logstash-2015.05.12 is within the threshold period (30 days).
2015-05-22 14:04:11,951 INFO logstash-2015.05.13 is within the threshold period (30 days).
2015-05-22 14:04:11,952 INFO logstash-2015.05.20 is within the threshold period (30 days).
2015-05-22 14:04:11,952 INFO logstash-2015.05.21 is within the threshold period (30 days).
2015-05-22 14:04:11,952 INFO logstash-2015.05.22 is within the threshold period (30 days).
2015-05-22 14:04:11,953 INFO logstash-2015.05.23 is within the threshold period (30 days).
2015-05-22 14:04:11,953 INFO CLOSE index operations completed.
2015-05-22 14:04:11,953 INFO Done in 0:00:00.071272.
2015-05-22 14:04:11,995 INFO Job starting...
2015-05-22 14:04:12,001 INFO Beginning DELETE operations...
SUCCESS
2015-05-22 14:04:12,032 INFO logstash-2015.04.23 is within the threshold period (30 days).
2015-05-22 14:04:12,033 INFO logstash-2015.04.24 is within the threshold period (30 days).
2015-05-22 14:04:12,033 INFO logstash-2015.04.25 is within the threshold period (30 days).
2015-05-22 14:04:12,034 INFO logstash-2015.04.26 is within the threshold period (30 days).
2015-05-22 14:04:12,034 INFO logstash-2015.04.27 is within the threshold period (30 days).
2015-05-22 14:04:12,034 INFO logstash-2015.04.28 is within the threshold period (30 days).
2015-05-22 14:04:12,035 INFO logstash-2015.04.29 is within the threshold period (30 days).
2015-05-22 14:04:12,035 INFO logstash-2015.04.30 is within the threshold period (30 days).
2015-05-22 14:04:12,035 INFO logstash-2015.05.01 is within the threshold period (30 days).
2015-05-22 14:04:12,036 INFO logstash-2015.05.02 is within the threshold period (30 days).
2015-05-22 14:04:12,036 INFO logstash-2015.05.03 is within the threshold period (30 days).
2015-05-22 14:04:12,036 INFO logstash-2015.05.04 is within the threshold period (30 days).
2015-05-22 14:04:12,037 INFO logstash-2015.05.05 is within the threshold period (30 days).
2015-05-22 14:04:12,037 INFO logstash-2015.05.06 is within the threshold period (30 days).
2015-05-22 14:04:12,037 INFO logstash-2015.05.07 is within the threshold period (30 days).
2015-05-22 14:04:12,038 INFO logstash-2015.05.08 is within the threshold period (30 days).
2015-05-22 14:04:12,038 INFO logstash-2015.05.09 is within the threshold period (30 days).
2015-05-22 14:04:12,038 INFO logstash-2015.05.10 is within the threshold period (30 days).
2015-05-22 14:04:12,039 INFO logstash-2015.05.11 is within the threshold period (30 days).
2015-05-22 14:04:12,039 INFO logstash-2015.05.12 is within the threshold period (30 days).
2015-05-22 14:04:12,039 INFO logstash-2015.05.13 is within the threshold period (30 days).
2015-05-22 14:04:12,039 INFO logstash-2015.05.20 is within the threshold period (30 days).
2015-05-22 14:04:12,040 INFO logstash-2015.05.21 is within the threshold period (30 days).
2015-05-22 14:04:12,040 INFO logstash-2015.05.22 is within the threshold period (30 days).
2015-05-22 14:04:12,040 INFO logstash-2015.05.23 is within the threshold period (30 days).
2015-05-22 14:04:12,041 INFO DELETE index operations completed.
2015-05-22 14:04:12,041 INFO Done in 0:00:00.072961.
2015-05-22 14:04:12,048 INFO Job starting...
2015-05-22 14:04:12,056 INFO Beginning SNAPSHOT operations...
2015-05-22 14:04:12,114 INFO Job starting...
2015-05-22 14:04:12,114 INFO Default timeout of 30 seconds is too low for command SNAPSHOT. Overriding to 21,600 seconds (6 hours).
2015-05-22 14:04:12,121 INFO Beginning SNAPSHOT operations...
2015-05-22 14:04:12,151 INFO Attempting to create snapshot for index logstash-2015.04.23.
2015-05-22 14:04:12,186 INFO Skipping index logstash-2015.04.23: Already optimized.
2015-05-22 14:04:12,186 INFO Attempting to optimize index logstash-2015.04.24.
2015-05-22 14:04:12,491 INFO Skipping index logstash-2015.04.24: Already optimized.
2015-05-22 14:04:12,492 INFO Attempting to optimize index logstash-2015.04.25.
2015-05-22 14:04:12,788 INFO Skipping index logstash-2015.04.25: Already optimized.
2015-05-22 14:04:12,789 INFO Attempting to optimize index logstash-2015.04.26.
2015-05-22 14:04:13,074 INFO Skipping index logstash-2015.04.26: Already optimized.
2015-05-22 14:04:13,075 INFO Attempting to optimize index logstash-2015.04.27.
2015-05-22 14:04:13,382 INFO Skipping index logstash-2015.04.27: Already optimized.
2015-05-22 14:04:13,382 INFO Attempting to optimize index logstash-2015.04.28.
2015-05-22 14:04:13,684 INFO Skipping index logstash-2015.04.28: Already optimized.
2015-05-22 14:04:13,685 INFO Attempting to optimize index logstash-2015.04.29.
2015-05-22 14:04:14,017 INFO Skipping index logstash-2015.04.29: Already optimized.
2015-05-22 14:04:14,018 INFO Attempting to optimize index logstash-2015.04.30.
2015-05-22 14:04:14,268 INFO Skipping index logstash-2015.04.30: Already optimized.
2015-05-22 14:04:14,268 INFO Attempting to optimize index logstash-2015.05.01.
2015-05-22 14:04:14,540 INFO Skipping index logstash-2015.05.01: Already optimized.
2015-05-22 14:04:14,540 INFO Attempting to optimize index logstash-2015.05.02.
2015-05-22 14:04:14,831 INFO Skipping index logstash-2015.05.02: Already optimized.
2015-05-22 14:04:14,831 INFO Attempting to optimize index logstash-2015.05.03.
2015-05-22 14:04:15,112 INFO Skipping index logstash-2015.05.03: Already optimized.
2015-05-22 14:04:15,113 INFO Attempting to optimize index logstash-2015.05.04.
2015-05-22 14:04:15,118 INFO Attempting to delete snapshot for index logstash-2015.04.20.
2015-05-22 14:04:15,398 INFO Skipping index logstash-2015.05.04: Already optimized.
2015-05-22 14:04:15,399 INFO Attempting to optimize index logstash-2015.05.05.
2015-05-22 14:04:15,698 INFO Skipping index logstash-2015.05.05: Already optimized.
2015-05-22 14:04:15,698 INFO Attempting to optimize index logstash-2015.05.06.
2015-05-22 14:04:15,964 INFO Skipping: A snapshot with name 'logstash-2015.04.23' already exists.
2015-05-22 14:04:15,965 INFO Attempting to create snapshot for index logstash-2015.04.24.
2015-05-22 14:04:15,994 INFO Skipping index logstash-2015.05.06: Already optimized.
2015-05-22 14:04:15,995 INFO Attempting to optimize index logstash-2015.05.07.
2015-05-22 14:04:16,300 INFO Skipping index logstash-2015.05.07: Already optimized.
2015-05-22 14:04:16,300 INFO Attempting to optimize index logstash-2015.05.08.
2015-05-22 14:04:16,591 INFO Skipping index logstash-2015.05.08: Already optimized.
2015-05-22 14:04:16,591 INFO Attempting to optimize index logstash-2015.05.09.
2015-05-22 14:04:16,708 INFO Skipping: A snapshot with name 'logstash-2015.04.24' already exists.
2015-05-22 14:04:16,708 INFO Attempting to create snapshot for index logstash-2015.04.25.
2015-05-22 14:04:16,845 INFO Skipping index logstash-2015.05.09: Already optimized.
2015-05-22 14:04:16,846 INFO Attempting to optimize index logstash-2015.05.10.
2015-05-22 14:04:17,042 INFO Skipping: A snapshot with name 'logstash-2015.04.25' already exists.
2015-05-22 14:04:17,043 INFO Attempting to create snapshot for index logstash-2015.04.26.
2015-05-22 14:04:17,129 INFO Skipping index logstash-2015.05.10: Already optimized.
2015-05-22 14:04:17,129 INFO Attempting to optimize index logstash-2015.05.11.
2015-05-22 14:04:17,396 INFO Skipping: A snapshot with name 'logstash-2015.04.26' already exists.
2015-05-22 14:04:17,397 INFO Attempting to create snapshot for index logstash-2015.04.27.
2015-05-22 14:04:17,433 INFO Skipping index logstash-2015.05.11: Already optimized.
2015-05-22 14:04:17,434 INFO Attempting to optimize index logstash-2015.05.12.
2015-05-22 14:04:17,751 INFO Skipping index logstash-2015.05.12: Already optimized.
2015-05-22 14:04:17,751 INFO Attempting to optimize index logstash-2015.05.13.
2015-05-22 14:04:17,868 INFO Skipping: A snapshot with name 'logstash-2015.04.27' already exists.
2015-05-22 14:04:17,869 INFO Attempting to create snapshot for index logstash-2015.04.28.
2015-05-22 14:04:18,113 INFO Skipping index logstash-2015.05.13: Already optimized.
2015-05-22 14:04:18,114 INFO Attempting to optimize index logstash-2015.05.20.
2015-05-22 14:04:18,241 INFO Skipping: A snapshot with name 'logstash-2015.04.28' already exists.
2015-05-22 14:04:18,242 INFO Attempting to create snapshot for index logstash-2015.04.29.
2015-05-22 14:04:18,267 INFO Optimizing index logstash-2015.05.20 to 2 segments per shard. Please wait...
2015-05-22 14:04:18,498 INFO logstash-2015.05.20: Successfully optimized.
2015-05-22 14:04:18,498 INFO logstash-2015.05.21 is within the threshold period (2 days).
2015-05-22 14:04:18,499 INFO logstash-2015.05.22 is within the threshold period (2 days).
2015-05-22 14:04:18,499 INFO logstash-2015.05.23 is within the threshold period (2 days).
2015-05-22 14:04:18,499 INFO OPTIMIZE index operations completed.
2015-05-22 14:04:18,500 INFO Done in 0:00:06.696626.
2015-05-22 14:04:18,610 INFO Skipping: A snapshot with name 'logstash-2015.04.29' already exists.
2015-05-22 14:04:18,611 INFO Attempting to create snapshot for index logstash-2015.04.30.
2015-05-22 14:04:18,965 INFO Skipping: A snapshot with name 'logstash-2015.04.30' already exists.
2015-05-22 14:04:18,965 INFO Attempting to create snapshot for index logstash-2015.05.01.
2015-05-22 14:04:19,299 INFO Skipping: A snapshot with name 'logstash-2015.05.01' already exists.
2015-05-22 14:04:19,300 INFO Attempting to create snapshot for index logstash-2015.05.02.
2015-05-22 14:04:19,646 INFO Skipping: A snapshot with name 'logstash-2015.05.02' already exists.
2015-05-22 14:04:19,647 INFO Attempting to create snapshot for index logstash-2015.05.03.
2015-05-22 14:04:20,050 INFO Skipping: A snapshot with name 'logstash-2015.05.03' already exists.
2015-05-22 14:04:20,050 INFO Attempting to create snapshot for index logstash-2015.05.04.
2015-05-22 14:04:20,421 INFO Skipping: A snapshot with name 'logstash-2015.05.04' already exists.
2015-05-22 14:04:20,421 INFO Attempting to create snapshot for index logstash-2015.05.05.
2015-05-22 14:04:20,799 INFO Skipping: A snapshot with name 'logstash-2015.05.05' already exists.
2015-05-22 14:04:20,800 INFO Attempting to create snapshot for index logstash-2015.05.06.
Traceback (most recent call last):
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 736, in <module>
main()
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 731, in main
arguments.func(client, **argdict)
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 585, in command_loop
skipped = op(client, index_name, **kwargs)
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 424, in _delete_snapshot
client.snapshot.delete(repository=kwargs['repository'], snapshot=snap_name)
File "/usr/lib/python2.6/site-packages/elasticsearch/client/utils.py", line 68, in _wrapped
return func(*args, params=params, **kwargs)
File "/usr/lib/python2.6/site-packages/elasticsearch/client/snapshot.py", line 34, in delete
_make_path('_snapshot', repository, snapshot), params=params)
File "/usr/lib/python2.6/site-packages/elasticsearch/transport.py", line 284, in perform_request
status, headers, data = connection.perform_request(method, url, params, body, ignore=ignore, timeout=timeout)
File "/usr/lib/python2.6/site-packages/elasticsearch/connection/http_urllib3.py", line 55, in perform_request
self._raise_error(response.status, raw_data)
File "/usr/lib/python2.6/site-packages/elasticsearch/connection/base.py", line 97, in _raise_error
raise HTTP_EXCEPTIONS.get(status_code, TransportError)(status_code, error_message, additional_info)
elasticsearch.exceptions.TransportError: TransportError(503, u'RemoteTransportException[[617c6cbc-2cb5-4d2b-aae3-445ce04d3040][inet[/xx.xx.1.247:9300]][cluster/snapshot/delete]]; nested: ConcurrentSnapshotExecutionException[[NLS_BACKUP:logstash-2015.04.20] another snapshot is currently running cannot delete]; ')
Processed 1 global jobs.
Then 10 minutes later, I see this in the log
2015-05-22 14:13:13,634 INFO logstash-2015.05.06: Successfully created snapshot.
2015-05-22 14:13:13,635 INFO Attempting to create snapshot for index logstash-2015.05.07.
Backups all the way to yesterday's index are completed. I set the job to run tomorrow. Will let you know how it goes. Inconsistency is definitely a concern.
Let us know - I've seen cases of inconsistency before, it would be good to know if your issue is resolved.
It looks like this backup failed because another was already in progress.elasticsearch.exceptions.TransportError: TransportError(503, u'RemoteTransportException[[617c6cbc-2cb5-4d2b-aae3-445ce04d3040][inet[/xx.xx.1.247:9300]][cluster/snapshot/delete]]; nested: ConcurrentSnapshotExecutionException[[NLS_BACKUP:logstash-2015.04.20] another snapshot is currently running cannot delete]; ')
