Event Handler is not running
Julie
Post by Julie »
Here is my configuration and the script:
        command_name check_pager
        command_line $USER1$/check_pager
        use                         generic-service
        host_name                   server_name
        service_description         HTTP port:8060
        check_command               check_http!-H server_name -p 8040
        check_interval              1
        retry_interval              1
        max_check_attempts          5
        notification_period         24x7
        notification_interval       5
        contact_groups              team-pager
        event_handler_enabled       1
        event_handler               check_pager
>>cat /usr/local/nagios/libexec/check_pager
#!/bin/bash
set -x
LOGFILE="/tmp/test.log"
touch $LOGFILE
echo Test `date` >> $LOGFILE
exit 0
>>ls -l /usr/local/nagios/libexec/check_pager
-rwxr-xr-x 1 root     root      171 May  5 15:28 check_pager
Because I put the wrong port in the check command, the check should always fail. I did get the service notification in the /usr/local/nagios/var/nagios.log:
[1430864078] SERVICE NOTIFICATION: Julie;server-name;HTTP port:8060;CRITICAL;notify-service-by-email;Connection refused
But the event handler script check_pager has never been executed. The /tmp/test.log has never been created. If I manually run ./check_pager as user nagios, then the script does create the log file.
Does anyone know why the event handler script not running?
Re: Event Handler is not running
Could you run the following and post back the output?
grep event /usr/local/nagios/etc/nagios.cfg
