refer to the topic http://support.nagios.com/forum/viewtop ... 38&t=32310
i have configured one of node to http to https redirect, however, it still said no data received.
i only configured one of servers to run https, should i configure all servers to run https?
Re: http to https redirect
Yes, please give that a try.i only configured one of servers to run https, should i configure all servers to run https?
What do you mean no data received? Are the logs not reaching Nagios Log Server? This would not have to do with HTTP(S), but rather the Cluster Hostname you input at "Global Configuration". http://support.nagios.com/forum/viewtop ... 38&t=32310i have configured one of node to http to https redirect, however, it still said no data received.
That hostname will need to be setup via DNS by you - the most typical setup is round robin DNS that points to every IP in the NLS cluster.
pccwglobalit
thanks for help. it was working now.
No problem - I'll lock this thread out. If you have any other questions or issues, feel free to open further threads. Thanks!
