How to implement nagios monitoring for JVM in Windows 2008
ganeshanrs1983
Post by ganeshanrs1983 »
Team,
Could you please help me how to implement nagios monitoring for JVM (java virtual machine) in windows 2008 server.
jdalrymple
Skynet Drone
Re: How to implement nagios monitoring for JVM in Windows 20
Post by jdalrymple »
That's a pretty abstract question. Are you trying to make sure that a JVM is being used by some java process? You could just monitor for the java.exe process (nsclient can handle this easily) if so. Can you be a little more clear on your use-case then maybe we can offer a more clear answer?
meveno
Post by meveno »
How could you monitor a jvm, launched through a service (which use a exe-wrapper to finally launch the jvm) ?
I want to monitor the heap usage and gc activity.
I've tried to use check_jvm but It seems to be made for linux and my tries on Windows were not successfull ;)
Any hint or advice ?
abrist
Red Shirt
Post by abrist »
Is checking through JMX remote a possibility? If so, you may want to look at:
https://exchange.nagios.org/index.php?o ... =check_jmx
