Extremely high load spikes - rebuild database?
ira
Post by ira »
Hi there,
I've got a liscensed version but I can't seem to post in the official support forum..
I'm having high load spikes.
At the start of each spike I'm getting:
Runtime Warning2015-05-08 07:01:29Warning: Host performance data file processing command '/bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/1431032481.perfdata.host' timed out after 5 seconds
output "from cat /usr/local/nagios/etc/nagios.cfg | grep 'broker'"
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
event_broker_options=-1
A sanitized system profile:
Nagios XI Version : 2014R2.7
nagios 2.6.32-504.12.2.el6.i686 i686
CentOS release 6.6 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/42.0.2311.135 Safari/537.36
Server Name: developer
Server Address: 192.168.x.x
Server Port: 80
Date/Time
Nagios XI Data
License ends in: STUORM
nagios (pid 23408) is running...
NPCD running (pid 1514).
ndo2db (pid 1592) is running...
CPU Load 15: 2.42
Total Hosts: 61
Total Services: 343
Function 'get_base_uri' returns: http://developer/nagiosxi/
Function 'get_base_url' returns: http://developer/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://developer/nagiosxi/includes/comp ... rofile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.044 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.035 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.039 ms
--- localhost.localdomain ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 0.035/0.039/0.044/0.006 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2015-05-08 09:38:27-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: "/usr/local/nagiosxi/tmp/ccm_index.tmp"
0K ........ 22.7M=0s
2015-05-08 09:38:28 (22.7 MB/s) - "/usr/local/nagiosxi/tmp/ccm_index.tmp" saved [8385]
Re: Extremely high load spikes - rebuild database?
Have you checked to see what process has the highest CPU usage?
top | head -15
Do you have any errors in the mysqld.log (crashed tables)?
tail -20 /var/log/mysqld.log
ira
Post by ira »
mysqld.log is showing the following error:
150509  7:18:51 [Warning] Disk is full writing '/tmp/SThOiQty' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
150509  7:18:51 [Warning] Retry in 60 secs. Message reprinted in 600 secs
150510  7:17:08 [Warning] Disk is full writing './nagios/nagios_systemcommands.MYD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
150510  7:17:08 [Warning] Retry in 60 secs. Message reprinted in 600 secs
150511  7:17:14 [Warning] Disk is full writing './nagios/nagios_contactnotificationmethods.TMD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
But having a look at the disk for /tmp and the database store at"/var/lib/mysql/nagios/":
root@nagios:~ $ df -P /var/lib/mysql/nagios/ | tail -1 | cut -d' ' -f 1
/dev/mapper/VolGroup-lv_root
Follow up:
root@nagios:~ $ df -h
Filesystem            Size  Used Avail Use% Mounted on
                       27G   24G  2.5G  91% /
tmpfs                 1.3G     0  1.3G   0% /dev/shm
/dev/sda1             477M  110M  342M  25% /boot
Now there's 2.5G free on "/dev/mapper/VolGroup-lv_root", that seems like plenty of space. And it's not an inodes issue:
root@nagios:~ $ df -i
Filesystem            Inodes  IUsed   IFree IUse% Mounted on
                     1792752 115783 1676969    7% /
tmpfs                 185171      1  185170    1% /dev/shm
/dev/sda1             128016     64  127952    1% /boot
I'll try to see what is causing the CPU spike when it occurs next.
How large is the database? You may need twice as much space as the size of the database. The "Disk is full" message in the log is quite clear. You will need to add more disk space.
