Getting Invalid Output On Nagios
rlinux57
Post by rlinux57 »
I have created my own plugin to check the number of testing email accounts on linux server.
It gives valid output on remote host:
#/usr/lib/nagios/plugins/check_testaccounts -w 1 -c 2
1
When i have run that plugin on nagios server it gives an invalid output:
#/usr/local/nagios/libexec/check_nrpe -c check_testaccounts -H spelljob.com 1 2
Please find the attachment plugin.
tplugin.txt
(174 Bytes) Downloaded 393 times
Re: Getting Invalid Output On Nagios
Plugins need to have a valid exit code of 0 for OK, 1 for Warning, 2 for Critical, or 3 for Unknown. Simply outputting the results of the check will not suffice.
Also, did you configure NRPE to allow arbitrary plugin arguments?
rlinux57
Post by rlinux57 »
I have allow the arguments in nrpe.cfg
Kindly check the attachment plugin i have edit exit code as per your direction.
tplugin.txt
(763 Bytes) Downloaded 371 times
Post by Box293 »
Please show us the nrpe command definition for this on the remote host.
Also, did you test this on the remote host as the user nagios?
su nagios
rlinux57
Post by rlinux57 »
On remote host working fine:
WARNING
nrpe.cfg command definition on remote host:
command[check_testaccounts]=/usr/lib/nagios/plugins/check_testaccounts -w 1 -c 2
Post by Box293 »
A couple of things here.
rlinux57 wrote:When i have run that plugin on nagios server it gives an invalid output:
rlinux57 wrote:nrpe.cfg command definition on remote host:
So in your nrpe command definition you have defined the warning and critical thresholds, so you don't need to use them in your nrpe command:
If you did want to send them, then you would need:
command[check_testaccounts]=/usr/lib/nagios/plugins/check_testaccounts -w $ARG1$ -c $ARG2$
/usr/local/nagios/libexec/check_nrpe -c check_testaccounts -H spelljob.com -a 1 2
NOTE: To send arguments you must use the -a flag.
rlinux57
Post by rlinux57 »
Still it shows on nagios server:
[root@monitors ~]# /usr/local/nagios/libexec/check_nrpe -c check_testaccounts -H spelljob.com -a 1 2
NRPE: Unable to read output
Post by Box293 »
To remove dns as an issue, instead of using spelljob.com, use the IP Address.
rlinux57
Post by rlinux57 »
Still getting error.
I have define command in nagios server as:
command_name check_testaccounts
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_testaccounts $ARG1$ $ARG2$
jdalrymple
Skynet Drone
Post by jdalrymple »
rlinux57 wrote:On remote host working fine:
WARNING
It looks like you're running it as root when you test it. When nrpe runs the test script it runs as user nagios. Can you test as user nagios and see if it works. If it does then we will look elsewhere. If it doesn't, you need to resolve that.
