After a fair bit of googling I can't find an obvious way to change the format of the $DATE$ variable.
Trying to monitor log files whose names end with YYYYMMDD, $DATE$ gives me MM-DD-YYYY.
Thank you.
How to change $DATE variable format
gsl_ops_practice
Re: How to change $DATE variable format
There are a few options to change it, but none appear to match what you need:
http://nagios.sourceforge.net/docs/3_0/ ... ate_format
We can put in a Core feature request for additional formats if you would like, but that would take some time to implement. The faster option, if possible depending on how you are using this, is to use a wrapper script to provide the date format.
gsl_ops_practice
Can you please how I would go about setting up a wrapper script? Definitely faster than waiting for a feature to be added
Alex
Alex
Sure thing. First I need to see how you are monitoring these logs. Can you post the check command and plugin you are using? The more info I have about the setup the better.
gsl_ops_practice
This is my command definition, we deployed a check_file_age script on all of our hosts that we need to monitor.
check_nrpe!check_file_age!-a '-w 3600 -c 5400 -f /home/application/apps/cli/log/cli-message-details.log.$DATE$'!!!!!!
You could create a bash script, i.e. "check_file_age_wrapper".
and use it as such:
#!/bin/bash
d=`date +%Y%m%d`
/usr/local/nagios/libexec/check_file_age -w $1 -c $2 -f $3.$dCode: Select all
/usr/local/nagios/libexec/check_file_age_wrapper 3600 5400 /home/application/apps/cli/log/cli-message-details.logBe sure to check out our Knowledgebase for helpful articles and solutions!
gsl_ops_practice
I had to add a new check with a new name and then the wrapper script started to return valid results.
Thank for your help, please mark this thread closed.
