Reinstall instructions
What are the instructions in reinstalling Nagios Log Server? I ran the 'fullinstall' script, but it retained all my settings. I would like to to a clean, fresh reinstall on my cluster and all its nodes.
Re: Reinstall instructions
In my experience:
At this point, re-try your fresh install.
rm -rf /usr/local/nagioslogserver
rm -rf /var/www/html/nagioslogserverRe: Reinstall instructions
That did it. Thank you. By the way, things were working okay for a day after our remote session, but I started having shard issues after that. I figured it would be best to just start fresh and do everything right from the beginning. Thanks again for all your help!jolson wrote:In my experience:At this point, re-try your fresh install.Code: Select all
rm -rf /usr/local/nagioslogserver rm -rf /var/www/html/nagioslogserver
No problem, glad to hear you're starting fresh - there are a lot of moving parts in Log Server, it's much easier to do it right once you have a good understanding of it all. I'll lock this thread up - thanks for the kind words!
