I have two identical Nagios servers and wish to export the config from one to another.
Both are running the Centos VMware 64bit version
I have tried copying the latest snapshot from one server to the other and then restoring it, and running an import through the core config manager…
When I go into the core config manager I can see all of my hosts, and services, they are all set to active and the status is applied and I have restarted the server.
But when I go to the homepage the only server that is showing up is the default localhost one, there are no other groups or servers.
Copying Config from one Server to Another
Re: Copying Config from one Server to Another
Were you able to apply configuration successfully? Do you get any config errors, when you run the Write Config Tool?
CCM->Write Config Files->Write->Verify
Is this a source install or one of our VMs? What version of Nagios XI are you using?
This is the VM version, 4.0.8
Hmmmm, it looks like I'm getting millions of duplicate warnings...
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Disk - Average Logical Disk Queue Length R' on host 'ALHIMSS01' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 81)
Warning: Duplicate definition found for service 'Disk - Average Logical Disk Queue Length R' on host 'NBUMAS02' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 81)
Warning: Duplicate definition found for service 'Disk - Average Logical Disk Queue Length R' on host 'ORCRIS02' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 81)
Warning: Duplicate definition found for service 'Disk - Average Logical Disk Queue Length S' on host 'NBUMAS02' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 99)
Warning: Duplicate definition found for service 'Disk - Average Logical Disk Queue Length S' on host 'SECSPM02' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 99)
Warning: Duplicate definition found for service 'Disk - Logical Disk Split IO-Sec R' on host 'ALHIMSS01' (config file '/usr/local/nagios/etc/services/Windows Servers.cfg', starting on line 173)
Nagios Core 4.0.8
License: GPL
Warnings won't cause apply configuration to fail.
Did you actually apply configuration after clicking on the "Verify" button?
Yes, the configuration has been applied
I tried deleting all of the hosts and services and importing them again but the same issue is happening.
I'm thinking of just flattening the machine and starting again to be honest- I really need to get this working!
Is there a better process for copying the config from one server to another?
I you would like to migrate XI to a new server (move ALL of the configs), you could following this document:
You will need to:
1. Backup the "old" server
2. Perform a fresh, clean install of XI on the "new" server (preferably the same OS/architecture/XI version)
3. Move the backup created in step one to the new server
4. Restore from the backup, following the document above
If you need to import SOME of the configs, you can follow this document:
You will need to:
Yeah that's worked fine
Thanks!
Thanks!
Great! I am glad I could help!
I will be locking this topic. If you have any more questions/issues, please start a new thread.
