I have got an error while setting up email notification , screen shot is attached please have a look at it.
Help me out in this issue please.
email settings error
nagiostool
Re: email settings error
Nagiostool,
Are you sure you've entered the SMTP information correctly? That error generally means the login/SSL settings are not correct.
Nicholas Scott
